I have a question regarding actual positions of the constraints/ force vectors, and I'm a bit lost here.
My model is a square plate with four screws in its centre attaching it to an elevation. Also, four identical force vectors are applied to identical holes around the corners. I tried a few things, but I'm not sure how to proceed:
- I tried applying fixed constraints to the cylindrical faces in the centre of the plate, however, I'm not sure if i need to do the same to the corresponding edges.
- I suppose I need to add extra force vectors to the same holes to simulate clamping force from the screws.
- Is there anything else I missed?
- Is it a good idea to add extra pockets to the body to get more faces to apply constraints to?
- How do I ensure certain areas of the body stay as they are regardless of what's happened to the rest of it?
