[done] Developing a spreadsheet based loaf pan
papyblaise
Re: Developing a spreadsheet based loaf pan
Post by papyblaise »
Ulicad
Post by Ulicad »
This is known here - it did not help me, just can't male this work..
Regards, Ulicad / Uli
en: New FC-user, virgin to previous CAD-work, labouring on his new hobby Ulis Blog
de: Neuer FC-Nutzer, ohne vorhergehende CAD-Erfahrung, beschäftigt mit seinem neuen Hobby Ulis Blog
papyblaise
me neither :lol: :lol:
I never use Draft wb for sketch 2D but sketcher
Ulicad
Post by Ulicad »
Hello @Shalmeneser,
could you confirm from your experience, that this is true? It would end my hours of searching about Trimex to extend a line to a face/surface for good.
If yes, and this is understood correctly by myself, do you have an idea about the reason(s)?
Uli
Shalmeneser
Post by Shalmeneser »
Je dirais même plus, I never use Draft wb for sketch 2D but sketcher.
Roy_043
Post by Roy_043 »
Note that freecad.info is not an official FreeCAD site.
Ulicad
Post by Ulicad »
Roy_043 wrote: Sat Feb 18, 2023 10:45 am Note that freecad.info is not an official FreeCAD site.
Thank you for the info - I wondered about.
Would you have a confirmation to the matter as such? (Still struggling a lot with terminology..)
Roy_043
Post by Roy_043 »
The Draft_Trimex command can only find intersections with edges. But I do not see how that command can be useful in this context.
Roy_043
Post by Roy_043 »
My suggestion is attached. See Basic_Part_Design_Tutorial_019 for some of the concepts used.
Note that @papyblaise is cutting some corners in his model resulting in out of scope links. This is not advisable.
loafpan_roy.FCStd
(112.14 KiB) Downloaded 27 times
Ulicad
Post by Ulicad »
Hi everyone,
since I learned that the extrusion of a non closed line or plolyline to a surface or face can not be achieved by a reguar command in FC, the conceptual approach for an effective and conformant creation of the pan needs to be changed accordingly.
The approach intended until now was:
  • create the inner contour of the pan as a non-closed polyline, including the fillets on the bottom (compare the OP)
  • extrude this contour into a surface (face)
  • pad this face to result in a solid (provided padding of a non-planar surface is legal..)
  • create 6 nos. of identically shaped cutouts in the pan
  • apply chamfers as needed
The changed approach is:
  • create a full cross-section of the pan, including the fillets on the bottom
  • extrude this closed polyline into a solid
The difference of the above approaches may not be as 'dramatic' as I felt - can not truly judge as a noob..
Compared to the old approach, the new one needs approx. double the no. of lines, which I feel is a lot and clutters the tree. Especially when considering, that a line can not receive a fillets on either side, but must be divided into two lines to achieve this.
Your remarks to the now intended approach is very welcome and helps me to understand FC better!
Uli
Thanks Roy for your labour! Our posts practically crossed and I shall have a good look into it!
