[solved] Draft workbench - In-command shortcuts for polyline stopped working correctly
Hologram
Post by Hologram »
Since the latest weekly build, the in-command-shortcuts for the Draft Workbench Polyline command stopped working correctly.
In-command Shortcuts .png (112.86 KiB) Viewed 582 times
Now, when I press T to continue, it exits the command. The same happens when I use C to close (remapped it to C).
Version: 0.21.0.31790 (Git)
Hash: 23e240e017e6712e027d39d0ee764fd7a963e718
  * BIM 2021.12.0
  * Launcher
  * persistenttoolbars
  * SelectorToolbar
Roy_043
Re: Draft workbench - In-command shortcuts for polyline stopped working correctly
Post by Roy_043 »
Can't reproduce. Maybe your user.cfg got corrupted? Exit FreeCAD, rename that file and try again. If that does not help: try disabling the mods (move their folders).
Hologram
Post by Hologram »
Yes, that seems to be the case. What could be the cause?
Roy_043
Re: [solved] Draft workbench - In-command shortcuts for polyline stopped working correctly
Post by Roy_043 »
I have mentioned 2 actions, so you need to be more specific.
Hologram
Post by Hologram »
Oops, yes the User.cfg file got corrupted.
I have edited the hotkeys for the In-command shortcuts manually and now it works the way I intended it to.
So my question is how the User.cfg can get corrupted. Didn't open it in VSCode before, just used the GUI to make edits in FreeCAD itself.
Roy_043
Post by Roy_043 »
Hard to guess what caused the corruption. Maybe a string value that conflicted with XML?
