[Solved] Multi-transform does not repeat all selected features
mwlandolsi
Post by mwlandolsi »
Here an example of file with multitransform. The pad and the bottom fillet are repeated, but the draft and the upper fillet need to be repeated in another multitransform to get the result.
Screenshot from 2023-02-08 19-46-23.png (45.99 KiB) Viewed 701 times
OS: KDE Flatpak runtime (X-Cinnamon/cinnamon)
Version: 0.20.2.29603 (Git)
Python 3.10.6, Qt 5.15.7, Coin 4.0.0, Vtk 8.2.0, OCC 7.6.3
  * sheetmetal 0.2.60
  * frame 0.1.0
  * Assembly3 0.11.4
  * Curves 0.6.5
  * lattice2 1.0.0
  * freecad.gears 1.0.0
  * Render 2022.4.0
  * fasteners 0.4.51
fillet mirror error.FCStd
(53.71 KiB) Downloaded 38 times
Shalmeneser
Re: Multi-transform does not repeat all selected features
Post by Shalmeneser »
For the PartDesign_Mirrored, you must select features in Chronological order : https://wiki.freecad.org/PartDesign_Pol ... g_features
You should not sketch upon a face : TNP
Capture d’écran 2023-02-08 205855.jpg (28.32 KiB) Viewed 671 times
fillet mirror_SHALM.FCStd
(41.48 KiB) Downloaded 38 times
mwlandolsi
Think you very much.
