(SOLVED) Refine a step file?
thomas-neemann
Post by thomas-neemann »
can you delete these lines
in a step file in freecad?
busbar.step
(907.49 KiB) Downloaded 10 times
Last edited by thomas-neemann on Wed Feb 08, 2023 6:04 pm, edited 1 time in total.
easyw-fc
Re: Refine a step file?
Post by easyw-fc »
I converted shells to solid, made an union and refined
busbar-refined.FCStd
(444.38 KiB) Downloaded 8 times
thomas-neemann
easyw-fc wrote: Wed Feb 08, 2023 5:40 pm I converted shells to solid, made an union and refined
thank you very much, this is the solution. unfortunately I can not understand it. how do you create this?
thomas-neemann
I found it, thanks for the solution
easyw-fc
Re: (SOLVED) Refine a step file?
Post by easyw-fc »
@thomas-neemann
I would suggest you to use the following settings for STEP import/export:
thomas-neemann
easyw-fc wrote: Wed Feb 08, 2023 6:11 pm ...
Thanks for the tip, I saved the settings
