FeaturePython - Feature request,
keithsloan52
Post by keithsloan52 »
Please could we have a facility added to FeaturePython objects, that when the object is deleted a function is called.
At present there are functions onChange and executed.
Bit like with a C++ object it would be useful to have an opportunity to tidy things up.
TheMarkster
Re: FeaturePython - Feature request,
Post by TheMarkster »
keithsloan52 wrote: Wed Feb 08, 2023 8:22 am Please could we have a facility added to FeaturePython objects, that when the object is deleted a function is called.
There is an onDelete(self, vobj, subelements) function in the view provider object.
I use it in PDWrapper macro to remove child objects from the body when the wrapper object is deleted.
    def onDelete(self, vobj, subelements):
        #only remove children from the body if they are claimed and not native PD objects
        doc = FreeCAD.ActiveDocument
        body = doc.getObject(vobj.Object.Body)
        if vobj.Object.LinkedObject and vobj.Object.ClaimChildren:
            if vobj.Object.LinkedObject in body.Group:
                grp = body.Group
                if not vobj.Object.LinkedObject.isDerivedFrom("PartDesign::Feature") \
                and not vobj.Object.LinkedObject.isDerivedFrom("Part::Part2DObject") \
                and not vobj.Object.LinkedObject.isDerivedFrom("PartDesign::ShapeBinder"):
                    grp.remove(vobj.Object.LinkedObject)
                    body.Group = grp
                    vobj.Object.LinkedObject.ViewObject.Visibility = True
        #need to ensure the next feature in the tree's BaseFeature property points to our BaseFeature
        solids = [feat for feat in body.Group if feat.isDerivedFrom("PartDesign::Feature") and feat.BaseFeature == vobj.Object]
        if len(solids) == 1: #found it
            solids[0].BaseFeature = vobj.Object.BaseFeature
        #need also to set the tip to our object's base feature if our object is the current tip
        if hasattr(vobj.Object,"_Body") and vobj.Object._Body.Tip == vobj.Object and vobj.Object.BaseFeature:
            vobj.Object._Body.Tip = vobj.Object.BaseFeature
            vobj.Object.BaseFeature.ViewObject.Visibility = True
        if vobj.Object.Proxy.editingMode:
            vobj.Object.Proxy.exorciseGhosts()
            FreeCADGui.Control.closeDialog()
        return True
