Hello there!
Using 0.20.2 here. What would be a good way to mill this piece? I haven't had luck getting the 3d operations to work. Please do a recommendation and I'll try it!
Attaching model. Best regards.
Help milling a 3d piece with chamfers
- question.FCStd
- (55.85 KiB) Downloaded 22 times
Re: Help milling a 3d piece with chamfers
@GeneFC , thanks for your reply.
I wasn't able to do it but I just noticed that I needed to uncheck Boundary enforcement. Something that I see is that I need to learn to mill in an efficient way. In the attached file I see that there are many travels that could be faster.
In this case, what could I do?
- question.FCStd
- (74.19 KiB) Downloaded 23 times
3D surfacing will usually be very slow if you want close replication of the shape. That is just the nature of tracing a surface with a small tool.
There are lots of parameters in addition to boundary enforcement. I recommend experimenting.
I typically use the "line" pattern, often with a pass in the x-direction (cut pattern angle 0 degrees) and a pass in the y-direction (90 degrees). Offset does not typically work the way I would like, but it may be OK for you.
Make sure the stock is large enough. It does not make any difference at all what you may place on your machine; the stock in FreeCAD can be adjusted in any way you wish to make the patterns come out right.
I assume you want to cut the entire top surface along with the sides down to the base. In that case you should select every face or no faces at all. There might be an (incorrect) error message if you select nothing, but the process will work just fine, and it usually produces exactly the correct result.
Multi-pass vs. Single-pass depends mostly on materials, machines, and tooling. Single-pass is the fastest if the hardware can deal with it.
If you have specific questions, just continue to ask. There are several forum regulars who use 3D machining techniques.
Gene
Consider using a corner rounding end-mill.
- IMG_20230222_074018.png (141.49 KiB) Viewed 760 times
Would be my preference as well if the profile matches . Also available in pointy-tip style but bearing-type is more common.**
afaik Path can't currently use that toolshape auto-magic like it paths a chamfer tool.
**edit/when all you have is a router everything looks like wood.
translation: I took a closer look at the tool
Oh, I thought that was aluminium...
Use a regular end-mill on Path, the same diameter with your corner rounding end-mill and make a contour operation. Full depth of cut and as many steps as you like. You will have to change your 3D model to a rectangular, without the fillets and of course smaller. You can produce a usable g-code that way. Hope that makes sense...
If you can split your model in two parts and glue/screw them together afterwards, it will make your life a lot easier.
