Precisely Position Sub Shape Binder
Dear all,
I've downloaded the 3D model of a display and I would like to make a centered hole on a case to mount it.
I can measure the display and make Pocket, but I would like to use the display model instead. For that I've made a sub shape binder on the Box model: Here is where I found issues, how can I move the Binder to a precise location? Can a sketch on the box face be used to place a point on the Binder?
My final goal is to have the display centered on the box face, is this the correct workflow? are there alternatives?
Looking forward your ideas,
Best regards, Mauro.
Re: Precisely Position Sub Shape Binder
File ? Full version ?
If you are importing a file and trying to get a Shapebinder to attach to the right face, you might check this:
LCS doesn't line up with part I select
I was running into the problem like this and changing the Trace Support value fixed the problem for me.
Hello all,
- First I've downloaded the step file of display from Waveshare Wiki imported it and saved in freecad file.
- Second is a simple box (see attached) and also the shape binder with the surface I would like to pocket on the box face.
To clarify I'm looking for a way to move the shape binder precisely to the center of the box face so I can afterwards make the respective hole.
looking forward your reply,
currently there are two files:
- box.FCStd
- (14.78 KiB) Downloaded 6 times
Your sketch is upon a Plane.
Move the rectangle to be centered (Sketcher_ConstrainSymmetric) and you can use the Origin to set something later.
Hello Shalmeneser,
here is the display: in this case the display geometry that needs to be pocketed into the box is very simple (just a rectangle) and I can make a sketch of it quite easily but I'm thinking in a more complex shape using the sub shape binder would be useful but returning to my original question, is there a way to precisely move the sub shape binder to a point? for example a datum point or something similar?
the yellow part is not a sketch, it is a sub shape binder containing the geometry of the back of the display.Shalmeneser wrote: ↑Wed Feb 08, 2023 6:07 am Your sketch is upon a Plane.
Instead of moving the shapebinder it's easier to move the sketch...... Like Shalm say's.
It's almost always best to centre your sketches.
- boxBance.FCStd
- (13.02 KiB) Downloaded 3 times
It is not exactly the solution I was looking but it servers my purposes.
Thank you all for taking the time to help!
Ahhh, I get it now! you and Shalmeneser mean, don't move the shape binder, instead, move sketch that produces the box.
Either you move the chair, either the piano.
