"Length constraint in a sketch for a line with a value obtained using an alias in a spreadsheet"
2cv001
Post by 2cv001 »
I know the formula for adding a length constraint for a line, but I can only do it by putting a number (or number + unit) in the parameter corresponding to the length to be imposed.
This code is ok with my squetch :
App.getDocument('test').getObject('Sketch').addConstraint(Sketcher.Constraint('DistanceY',1,1,1,2,App.Units.Quantity("123,00 mm")))
I yould like to replace this number (here ("123,00 mm") with a formula as it is entered in the dialog box and allows, for example, to reference the alias of a cell in a spreadsheet to retrieve a value."
I tried
App.getDocument('test').getObject('Sketch').addConstraint(Sketcher.Constraint('DistanceY',1,1,1,2,App.Units.Quantity("Spreadsheet.Alias")))
I tried also
App.getDocument('test').getObject('Sketch').addConstraint(Sketcher.Constraint('DistanceY',1,1,1,2,App.Units.Quantity("=Spreadsheet.Alias")))
So how can we use such formula : 'Spreadsheet.Alias" ?
error message : ValueError: syntax error
Version: 2022.1128.26244 +5318 (Git)
Branch: LinkDaily
Hash: d45d221edcc7a757eb4e4eb638da0db5ed2759aa
Python version: 3.8.10
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.6.2
Locale: French/France (fr_FR)
Macro Sketch Constraint From Spreadsheet :
https://wiki.freecad.org/Macro_Sketch_C ... adsheet/fr
edwilliams16
Re: "Length constraint in a sketch for a line with a value obtained using an alias in a spreadsheet"
Post by edwilliams16 »
App.getDocument('test').getObject('Sketch').addConstraint(Sketcher.Constraint('DistanceY',1,1,1,2,Spreadsheet.Alias)))
assuming you put 123 mm in the cell.
2cv001
Post by 2cv001 »
IThanks !
tried your code but I have an error :
So,
My spreadsheet :
When I add a contraint directly like this
It is ok with Spreadsheet.Alias
When I try your code
I have this error :
NameError: name 'Spreadsheet' is not defined
I try with a number
App.getDocument('test').getObject('Sketch').addConstraint(Sketcher.Constraint('DistanceY',1,1,1,2,12))
and it is ok so the beginning of the code is ok
edwilliams16
I would have been less prone to have made a mistake if you had provided an appropriate FCStd file. All the indexes and names change when I try to make a test file.
Use
App.ActiveDocument.getObject('Spreadsheet').Alias)
in place of the length.
It already returns the length with units.
2cv001
Post by 2cv001 »
Your code is ok, but it's not exacly what I yould like. Sorry, I wasn't clear enough.
I would like the code to generate a constraint where the length is not just a number but a formula that fetches the value from an array.
I want that once this constraint is created, in its parameter corresponding to the length, there is a formula like "Spreadsheet.Alias" and not just a number "123" for a length of 123
Thus, if we change the value in the array, the length of the line will change automatically.
Once the constraint is created by the formula, it will be exactly the same as if you had entered the constraint by hand in this way:
Here is afile test
test.FCStd
(6.12 KiB) Downloaded 14 times
Made with
Version: 0.21.0.31340 (Git)
Hash: 856af2a12287a2d7c0d5ab23646be43af26b14b1
  * Assembly3 0.11.4
  * Curves 0.6.5
  * fasteners 0.4.26
  * Help 1.0.3
  * ThreadProfile 1.84.0
2cv001
Post by 2cv001 »
I succed
first to create the constraint with your code. Something like
App.getDocument('test').getObject('Sketch').addConstraint(Sketcher.Constraint('DistanceY',1,1,1,2,12.000000))
and then to change the constraint :
App.getDocument('test').Sketch.setExpression('Constraints[1]', u'Spreadsheet.Alias')
[1] is the constraint index
No way with only one code line ?
Edit just to say wy I did not find this before :
Becouse in tne python console with my everyday freecad version, the line such App.getDocument('test').Sketch.setExpression('Constraints[1]', u'Spreadsheet.Alias') does not apprear (branch LinkDayly). It does in 0.21 freecad version...
With this, I can manage, but isn't there a way to do it directly when creating the constraint?
edwilliams16
@2cv001
I wasn't explicit enough:
App.ActiveDocument.getObject('Sketch').addConstraint(Sketcher.Constraint('DistanceY',1,1,1,2,App.ActiveDocument.getObject('Spreadsheet').Alias))
substituting the 12 with the reference to it.
