Arch_Site has a couple of issues.
The most difficult problem is that if its Terrain property is empty it can show a 'ghost' of the objects in its Group. Open the attached FCStd file and change the Placement Angle of the Site object from 16 to 15 degrees to see that. If the Face object is selected as the Terrain the ghost disappears. But clearing the Terrain property then results in a ghost of the terrain still being shown for the Site.
I have played around with coin nodes to try to solve this, but did not succeed. The only solution that I could get to work is to always ensure a site has a Shape of its own (a Part.Vertex). See the attached PY file. But I do not know if this would be acceptable.
Some other issues related to transformations and missing __getstate__ and __setstate__ functions were also addressed in the attached PY file.
Source of the original error-Draft-SelectPlane.FCStd file:
viewtopic.php?t=75658
Related discussion about 'phantom elements':
viewtopic.php?f=10&t=74731
Trying to fix Arch_Site
- ArchSite.py
- (45.89 KiB) Downloaded 25 times
- error-Draft-SelectPlane.FCStd
- (207.11 KiB) Downloaded 26 times
Re: Trying to fix Arch_Site
Hello.Roy_043 wrote: ↑Tue Feb 07, 2023 11:16 am ...
This come from a total noob in Architecture, so probably with a different "point of view", so if is OT sorry.
From what I know everything should have a Shape, if not it is not a solid and could not have some properties and probably appear in the "treeview".
A simple point will work, even this simple point as a ViewProvider that show an "entire world", maybe using a line, that could have a placement and a rotations, as it is a "non sense" to rotate a vertex (or better, it has some sense in 3d but probably it is hard to guess by many users).
Maybe even a plane, that could be moved as example up and down (Z+ and Z-) retaining an "inclination".
And probably having the way to toggle between the "plane" and the "terrain" will help in a more natural way "to position" the terrain representation.
It is interesting, as I was not aware of the existence "Arch Site", if I have some spare time I will check code you posted.
I am thinking the main problem of the arch site is that it's actually a Part object. We could try to make it a BuildingPart, with a "Terrain" PropertyLink maybe, but that has no influence over the BuildingPart itself? Then the IFC exporter could easily pick that...
What would then be the function of the Site object? And would we then need a new Terrain object?
I have meanwhile found a solution for the coin nodes. Still working on some other issues.
Basically the site is there because it's an IFC feature. In a typical IFC file (99% of the IFC files out there are so), you have one IfcProject, which contains one IfcSite, which contains one or more IfcBuildings, which contain one or more IfcBuildingStoreys. So most BIM software will expect to find a Site. And the IFC site is usually a hybrid object, that has both a shape (the terrain itself) and serves as a container for other objects...
The Arch Site was created to fulfill that function. But now it looks to me we could simplify things by making it a container only. That would remove a series of problems. And it could have a slot so one can attach terrain geometry o it...
- markko martin
I think it's a good idea.
Then to generate the terrain geometry , should i use part design workbench or a new command in the arch / bim workbench?
It would be great to be able to import a dxf with contour levels and create the terrain geometry directly with arch/bim workbench.
Maybe it could be an idea for google summer of code ?
I insert a link to see how to create a terrain geometry in archicad:
https://www.youtube.com/watch?v=GcSzLOYFMBs
Loris
