Fully Constrained, Yet Won't Pad
TransJenna
Post by TransJenna »
Hi there,
I love all the help y'all have given me so far, but I have to ask another favor. I can't for the life of me figure out why I can't get this to pad. I even removed a constraint or two and yank on every single line segment and vertex. Nothing seems disconnected. All I get is a "Wire Is Not Closed" input error.
Thank Y'all.
-Jenna
Base 6.FCStd
(8.89 KiB) Downloaded 23 times
drmacro
Re: Fully Constrained, Yet Won't Pad
Post by drmacro »
Physical proximity of vertexes does not constitute coincident. Each set of vertexes must be marked coincident.
Either remove some dimensional constraints and wiggle lines until you find the loose vertexes or use the Validate sketch tool to find them.
https://wiki.freecad.org/Sketcher_ValidateSketch
TransJenna
I pulled on each vertex and none of them moved, and I also tried the Validate Sketch tool without finding any issues.
0mer0
Post by 0mer0 »
I only changed the angular constraints of 180° for the vertical constraint of the 3 points of the arc.
Base 6_2.FCStd
(24.21 KiB) Downloaded 17 times
TransJenna
Cool! Thanks.
GeneFC
Post by GeneFC »
TransJenna wrote: Tue Feb 07, 2023 1:29 am I pulled on each vertex and none of them moved, and I also tried the Validate Sketch tool without finding any issues.
The Validate Sketch tool in FC development version 0.21 shows the sketch error locations as "Highlight Troublesome Vertices".
Gene
Shalmeneser
Post by Shalmeneser »
:idea:
your sketch : 22 dimensions
mine : 8 dimensions
Base 6_SHALM.FCStd
(43.9 KiB) Downloaded 20 times
Capture d’écran 2023-02-07 092618.jpg (60.39 KiB) Viewed 525 times
