Operate on subobject in polyline (individual wire segments in joined wire)
Hologram
Post by Hologram »
In Rhino or Autocad, I often use subobject selection to move a portion of a polyline (joined wire). I also remove parts of a polyline thorugh subobject selection, so I can chamfer them with a zero distance (to make both line ends intersect). How does one do these things in FreeCAD?
1. For instance, if you want to move a line segment (not the entire line) how do you do that?
The stretch command doesn't seem to be working on wire objects (imported DXF, then upgraded the edges to wires).
And edit mode of curves only allows you to edit the individual vertices, or am I missing something there?
2. I am also struggling to delete intermediate segments of a line.
Just a demonstration of some typical use cases I have, which I would like to do in the draft workbench, if that's possible.
Delete subobject.gif (634.25 KiB) Viewed 339 times
Version: 0.21.0.31391 (Git)
Hash: 0ab2608a429f3a5ee9a63da9b66d13557655d7e4
  * BIM 2021.12.0
  * Launcher
  * persistenttoolbars
  * SelectorToolbar
Roy_043
Re: Operate on subobject in polyline (individual wire segments in joined wire)
Post by Roy_043 »
Some Draft commands have a subelement mode. See f.e. Draft_Move. Draft_Wires can be 'partially' stretched with Draft_Stretch.
Hologram wrote: Mon Feb 06, 2023 9:34 pm ...
But a "line" or better a segment have no "intermediate segments".
Terminology is the base of geometry.
In FreeCAD usually it is called a wire in most WB,some Wb have even a similar concept called "polyline" that is usually wrong as in FreeCAD segments could be even portions of curves in the "common sense" of curves, as there is Curve property that is a "specific thing".
on what WB you want to remove segments from a polyline or a wire?
Hologram
Post by Hologram »
It's for the Draft workbench @onekk. I'm trying to find out whether I can move a portion of my workflow to the draft workbench.
Hologram wrote: Tue Feb 07, 2023 9:17 am It's for the Draft workbench @onekk. I'm trying to find out whether I can move a portion of my workflow to the draft workbench.
Probably draft use wires, so edges could be extracted and moved, it is not difficult to do using python, there is Edges property that is a list and a list could be manipulated, (sometimes you could not really manipulate it but you have to copy, modify and reassign to the property, but it is an implementation detail).
edges could be moved and translated where you want, as they are "Geometrical objects", but you have to know something about how Topology an Geometry is implemented in FreeCAD, if you want:
Topology and Geometry Primer
https://forum.freecadweb.org/viewtopic. ... 89#p500989
Topology Geometry and so on by @Chris_G:
https://forum.freecadweb.org/viewtopic. ... 93#p500989
https://forum.freecadweb.org/viewtopic. ... 12#p345612
Outside and Inside for Offset of "open wires"
https://forum.freecadweb.org/viewtopic. ... 69#p628069
Consideration about 2D to 3D objects
https://forum.freecadweb.org/viewtopic. ... 11#p463511
Angles discussion about the 24 types of Cardan angles and similar
https://forum.freecadweb.org/viewtopic. ... 5&start=20
Zolko explanation (author of Assembly4)
https://forum.freecadweb.org/viewtopic. ... 14#p607514
