angle constraint oreinted on x-axis instead of lines
ovski
Post by ovski »
I'm having an issue with angle constraints that are not oriented on the lines but the x-axis.
Let me show you a working example on an older freecad version:
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
* A2plus 0.4.60i
* Assembly4 0.12.5
* Curves 0.6.5
* fasteners 0.4.54
* sheetmetal 0.2.61
All good, angles are displayed as they should be.
and now the same file on a current version of freecad, downloaded some minutes ago.
OS: Windows 10 Version 1903
here the angles are somehow connected to the x-axis. I can't find a way to orient them correctly on the point where two lines meet.
this is the same file opened in both versions, so I can't imaging what I'm doing wrong.
Is this a know bug?
angle_test.FCStd
(5.95 KiB) Downloaded 17 times
Re: angle constraint oreinted on x-axis instead of lines
You can always check the tracker. In this case you could find 8285.
Did you compile the non working version yourself?
ovski
Post by ovski »
How would I identify 8285? I tried to find a tracker but lost myself in the git hub page of freecad.
No, I downloaded the non working version from https://www.freecad.org/downloads.php?lang=de
This version was downloaded twice yesterday ond two different systems with the same effect.
Syres
Post by Syres »
I'll have a go at triaging the regression today so at least someone with more C++ skills can hopefully fix it.
ovski
Post by ovski »
Should I open a ticket or bug report somewhere or is it okay to keep this here in the forum?
Syres
Post by Syres »
ovski wrote: Mon Feb 06, 2023 9:40 am Should I open a ticket or bug report somewhere or is it okay to keep this here in the forum?
Please don't there's already duplicates in the issues section, most of the main updates are already in https://github.com/FreeCAD/FreeCAD/issues/8220 so I'm going to ask that https://github.com/FreeCAD/FreeCAD/issues/8285 is closed as a duplicate.
OK, so that triage was fairly quick, this regression is not a general 0.20.2 regression as first thought, it's specific to the Windows Libpack build. I'd thought to myself "Why have I not seen this on my Conda Linux build?" (I use 0.20.2 on a daily basis) because it doesn't occur. It also doesn't occur on the same system with the same config files using the Conda Windows build, it only occurs in the Libpack build so it appears to be a packaging issue at first glance and I don't have the capacity to compile Windows builds in order to prove that.
@chrisb I assume your MacOS build of 0.20.2 doesn't give this symptom either because it's built on Conda?
@uwestoehr Please be aware of this when you next release a LibPack build whether it be 0.20.3 or 0.21.x
ovski
Post by ovski »
Strange, I could not find those issues yesterday... seems like my google kung-fu was weak.
But I can confirm, that this does not happen on the Mac OS version.
tested on:
OS: macOS Mojave (10.14)
Version: 0.20.2.29603 (Git)
Locale: C/Default (C)
by the way: thank you for your quick replies and support!
uwestoehr
Post by uwestoehr »
Syres wrote: Mon Feb 06, 2023 9:53 am @uwestoehr Please be aware of this when you next release a LibPack build whether it be 0.20.3 or 0.21.x
I can reproduce the issue but don't know what could be the cause. Since FreeCAD 0.20 I updated the OCC library from 7.6.0 to 7.6.3. It seems there is a regression. Let's cross fingers that this is fixed by the next OCC bugfix release. I cannot go back to older OCC versions because the policy is to upgrade OCC only when there are reported bugfixes affecting FreeCAD users. So going back will fix the issue here but open other issues.
GeneFC
Post by GeneFC »
I am not convinced that it is related to the Libpack.
I regularly compile using the latest Libpack. This is a result of my testing just now.
Works
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.21.0.Unknown
  * FeedsAndSpeeds 0.5.0
  * FeedsAndSpeeds-master.zip
  * freecad.gears 1.0.0
  * Help 1.0.3
Fails
  * Help 1.0.3
Same computer, same user config, etc, etc. This happens to be on Windows 7, but Windows 11 shows the same behavior.
Gene
Syres wrote: Mon Feb 06, 2023 9:53 am @chrisb I assume your MacOS build of 0.20.2 doesn't give this symptom either because it's built on Conda?
Indeed, no problem here:
OS: macOS 13.0
Version: 0.21.0.31709 (Git)
Hash: e188802ca6997d2564e7570ab648462e6a059f87
  * FC_SU
  * DynamicData 2.46.0
  * dxf-library
  * fcgear 1.0.0
  * fasteners 0.4.54
  * sheetmetal 0.2.60
  * ExplodedAssembly
  * Curves 0.6.6
