Version 0.20.2, installed from Flatpak.
I'm having some issues with getting a subtractive pipe to work correctly. My intended use case is that I'm trying to use it simultaneously profile existing edges, as well as adding a rounded corner. Whatever I do, I can't seem to get it to do these actions smoothly. Not quite sure why this is, but potentially not helped by the angles between the planes.
I'd really appreciate anyone having a look at my model and being able to explain what I'm doing wrong/not understanding about the pipe function.
Current model...
Intended outcome (as previously modelled in Blender)...
Issues with understanding/using pipe tool
- Skatev2.2.FCStd
- (280.51 KiB) Downloaded 8 times
- papyblaise
Re: Issues with understanding/using pipe tool
it is necessary to lengthen the sketches so that there is no material left in the hatched angle
- scatev.JPG (35.61 KiB) Viewed 237 times
Thanks! I tried that, but I'm still getting a sharp edge on the top and bottom. Did you adjust anything else too? I'm not sure where my "line" sketch needs to be in relation to the "edges".
