Google Summer of Code 2023 - Coding! Up to July 10th
- Blacklight
Re: Google Summer of Code 2023 - Call for Ideas
I've submitted the motor design workflow proposal draft. While thinking of it, I figured out that since it would require defining material properties, the materials database can also be a good addition here, although we can currently do it by manually defining the properties. Also, I've listed the project size as medium, since I think I can make this project either very detailed or limit it's scope to fit in the timeframe. I'd prefer the former, but I don't know how long it will take yet.
I'm currently sick from dust allergy after dusting my room. Please review my proposals and make any suggestions.
Keep calm, and be nice to everyone!
Hey there, i'm David and i'd like to participate in this year's GSoC event. I've had an inital look at the code and prepared a draft proposal based on the Unified Measurement Facility task - https://github.com/FreeCAD/FreeCAD/issues/8561. As noted in the project list @kkremitzki would be the mentor. It would be great to get feedback:
The key difference to the existing task is that i'd like to exclude annotations like the Draft and TechDraw commands from the project as they don't seem to fit well. Secondly this project would include reworking existing commands rather than just combining them on the UI level.
I still have some open question:
- Is it possible to expand the timeframe for this project?
- Is it alright to focus on measurements only?
- Are there already other base commands which get extended by workbenches?
- Is there already an abstract representation of geometry in FreeCAD's base that could be used for the measure command which shouldn't know about specific geometry types?
- adrianinsaval
may I ask what existing commands do you intend to rework? Have you explored the existing measure tools? The issue description is not really just about "combining at UI level", most or all of them are very lacking so it really is about making a new tool that can satisfy the needs for most cases and can be used as a global toolbar.
I don't think that's desirable, a measure tool is most likely more useful if it knows about geometries.- Is there already an abstract representation of geometry in FreeCAD's base that could be used for the measure command which shouldn't know about specific geometry types?
Are you saying that in future, users who open Techdraw pages containing Annotations created in recent FreeCAD versions will be left with blank text everywhere? Maybe I'm the only user who add Annotations quite regularly to Tech drawings in order to point out specific requirements for the engineer(s) carrying out the work, (e.g. use of specific lubrication, plating spec, shot peening, acid dip), slightly alarming reading this. wandererfan do you have any input here purely regarding Techdraw?
Edit:remove mention ping
- adrianinsaval
Excluded from the GSoC project = not touchedSyres wrote: ↑Mon Mar 27, 2023 2:59 pm Are you saying that in future, users who open Techdraw pages containing Annotations created in recent FreeCAD versions will be left with blank text everywhere? Maybe I'm the only user who add Annotations quite regularly to Tech drawings in order to point out specific requirements for the engineer(s) carrying out the work, (e.g. use of specific lubrication, plating spec, shot peening, acid dip), slightly alarming reading this. @wandererfan do you have any input here purely regarding Techdraw?
This shouldn't have any effect on techdraw
Apologies for the noise.
Sorry this was actually confusing, i've described the planned approach in the chapter "project details" in the document.adrianinsaval wrote: ↑Mon Mar 27, 2023 2:24 pmmay I ask what existing commands do you intend to rework? Have you explored the existing measure tools? The issue description is not really just about "combining at UI level", most or all of them are very lacking so it really is about making a new tool that can satisfy the needs for most cases and can be used as a global toolbar.
This is more of an implementation detail. Afaik a global tool cannot and should not know anything about a geometry type that is defined in a workbench.adrianinsaval wrote: ↑Mon Mar 27, 2023 2:24 pmI don't think that's desirable, a measure tool is most likely more useful if it knows about geometries.
possibility to give a measurement without using dimensioning, dimensioning hides everything behind it
Re: Google Summer of Code 2023 - Deadline april 4th
Welcome @hlorus !
I cannot see your proposal - it says "access denied"...
The time of we give on the ideas (175h / 350h) is only our idea. Feel free to propose something else if you feel it's appropriate.
To all candidates: remember the deadline is next Tuesday, April 4th! We need your proposals in well before, so we have time to review!
A couple of hints to write your proposal:
Typical proposals should be around 3 or 4 pages, and contain:
Guidelines: https://google.github.io/gsocguides/stu ... a-proposal
Template: https://www.drupal.org/community/contri ... l-template
- A description of what you intend to do. That's where you explain what your project is
- Info about yourself: contact info, where you live, some background about yourself, where you studied/are studying, maybe some of your interests, etc. Things so we know you better.
- A commitment that you are ready to spend the necessary time on the project, and how you plan to spend it. It does not need to be a precise week by week schedule (but it's great if you do!), but grossly how you plan to work during the GSoC time. We want to see that you thought about it and are serious about it.
- Something about either previous involvement with open-source projects, or that you engaged with the community already, and all you can to demonstrate that you already took the necessary steps to know your subject: That you already installed the software, played with it, compiled it if that's something you'll need for your project, understood what needed to be done, etc.
Sorry about that, i've updated the link.
I ment expanding in terms of splitting the workload of 175h over a longer period. Basically what's written on the GSoC website (https://summerofcode.withgoogle.com/programs/2023):
"The standard timeline accounts for 12 week coding projects. Mentors and GSoC Contributors can agree to extend the coding period up to 22 weeks. "
