[solved] ViewIvStereo - What does Iv mean?
FBXL5
Post by FBXL5 »
I want to translate the Std ViewIvStereo... pages but have no clue what Iv could mean. :?
Please give me a hint if it is an abbreviation, or a typo and tell me what it represents, or that it can be omitted in translation.
david69
Re: ViewIvStereo - What does Iv mean?
Post by david69 »
FBXL5 wrote: Sun Feb 05, 2023 2:49 pmgive me a hint
check this page for example
https://wiki.freecad.org/Std_ViewIvStereoOff
I guess the Iv is part of the command, not sure.
The Iv presumably is the abbreviation for Inventor (aka OpenInventor). But the Iv is only used in the command name as context for the menu and tool tip text, i.e. it shouldn't appear inside a translatable string.
FBXL5
Post by FBXL5 »
david69 wrote: Sun Feb 05, 2023 3:55 pm
Yes it is part of the interal command name = wiki page name. The menu item is called Stereo Off.
The wiki page gives no clue about the meaning of "Iv"
I just realised that it is iv not Lv. Could it be "interleaved view" then?
.iv is the file extension for OpenInventor files and there this abbreviation comes from.
No. There is also a command Std_ViewIvStereoInterleavedRows so that if "Iv" meant interleave the command would be "View Interleave Stereo Interleaved Rows".
I think the fact that the Iv is part of the command name is because at the early days of FreeCAD the OCC viewer was used but due to performance issues and some other shortcomings we have switched to OpenInventor. So for some time two different viewers were used and to make sure that a command is specific to OpenInventor the Iv has been added.
FBXL5
Post by FBXL5 »
wmayer wrote: Sun Feb 05, 2023 4:53 pm So for some time two different viewers were used and to make sure that a command is specific to OpenInventor the Iv has been added.
Thank you, that makes sense. Knowing this convinces me that it is no problem to ignore it for translations nowadays
