In the Spreadsheet workbench, does anyone know whether the Alias highlight color can be changed?
There's no listing of the HEX code nor of an rgba value in the stylesheet that corresponds to this color, nor is there a color box in the preferences for the spreadsheet editor.
The issue appears to be more widespread, because it appears across all the default stylesheets and also in ExtremeProDark, so it appears to be hardcoded. Thing is, with any of the dark interface styles that use white letters (e.g. ExtremeProDark, Behave dark) it becomes impossible to read the contents of the cell.
Parameter A has an alias.
Parameter B has an alias, but is readable when I have the cell selected (you can style selected cells and their font color in the Stylesheet).
Parameter C shows that I am using a white letter styling as default.
[issue] Spreadsheet cell colour with Alias?
- MisterMaker
Re: [issue] Spreadsheet cell colour with Alias?
Should enable the theme not the stylesheet of extreme pro dark and then reboot.
It should be fixed by adding following code to the theme cfg file: (below is purple)
ExtremeProDark has this but you need to reboot Freecad.
<FCParamGroup Name="Spreadsheet">
<FCText Name="AliasedCellBackgroundColor">#9b4de6</FCText>
</FCParamGroup>
