weird issue - dimension not updating from expression, no errors
contemporiser
Post by contemporiser »
Simple furniture design made of boxes,problematic element - FrontSink -
if I set it's height with integer, it updates properly.
if I set it's height with an expression, it calculates the height properly inside the expression dialog, but Height remains unchanged.
it throws no warnings in the report view and commands in the python console look normal
>>> App.getDocument('law').Box064.setExpression('Height', u'550mm - 5mm')
submitting recompute object does nothing
OS: Linux Mint 20.3 (awesome)
law.FCStd
(93.77 KiB) Downloaded 13 times
Roy_043
Re: weird issue - dimension not updating from expression, no errors
Post by Roy_043 »
Recomputing the whole document fixes the issue here.
Version: 0.21.0.31709 (Git)
Hash: e188802ca6997d2564e7570ab648462e6a059f87
contemporiser
It does not work for me. Tried it. I just updated to the newest version, but the issue persists.
This is only one of several elements in my model that does it. I have simplified the model not to confuse everyone.
I see no pattern, in some cases it is position that doesn't update, in other a dimension.
dprojects
Post by dprojects »
contemporiser wrote: Sun Feb 05, 2023 8:26 am Simple furniture design made of boxes,problematic element - FrontSink -
I guess there is problem with Position.x expression, if you remove the expression it is working.
However, the expression Position.x looks correct, it is even recalculated during writing.
But looks like FreeCAD expression parser collapse on that...
EDIT: Try latest weekly build, there is no such issue at Version: 0.21.0.31772 (Git) AppImage
Thanks
Darek
github.com/dprojects
Jolbas
Post by Jolbas »
It's probably related to the issues in this thread which is partly fixed in 0.21. The Expression Engine sometimes can't find the correct evaluation order for sub-properties of placements and rotations.
