weekly build 31709: segmentation fault when starting on Linux
thomas-neemann
Re: weekly build 31709: segmentation fault when starting on Linux
Post by thomas-neemann »
this software combination also works
Version: 0.21.0.31772 (Git) AppImage
Hash: 87c5b891352580568592cbba0e746269f726c43c
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * InventorLoader 1.3.0
  * Curves 0.6.5
  * sheetmetal 0.2.61
Giulio Buccini
Post by Giulio Buccini »
wmayer wrote: Mon Feb 06, 2023 11:30 am Can FreeCAD_weekly-builds-31709-2023-02-02-conda-Linux-x86_64-py310.AppImage still be downloaded somewhere? I haven't found a link for it.
I tried to download and run the build 31772. Same result.
Giulio Buccini
onekk wrote: Mon Feb 06, 2023 11:23 am 16.04 is somewhat old, and obsolete from my point of view, some question:
- it is supported by Ubuntu as a LTS release.
- it receive security fixes.
- How much time it will take if some malware or ransomware will destroy or lock your data, due to a security flaw.
I still receive all of the updates, roughly every 20-30 days, including security fixes.
You can have the most updated OS version, but if you use old libraries you will get problems with an application in any case.
Usually, the problems with Freecad are somehow related to the C++ libs.
What version you have?
Could you run the command ldd /bin/bash on you computer?
Arch Linux so it is very different are usually arch library are quite up to date to upstream.
So we are confroning apples with oranges, they are round but they are very different.
As example I could not run 0.19 AppImage on my actual installation.
Giulio Buccini
Maybe I have to update just the Pyton libraries?
Mine is 3.10.x
There is nothing you have to upgrade on your system because the AppImage contains all 3rd party libraries it requires. When starting the AppImage it creates a mount point in /tmp (e.g. .mount_FreeCA55ab13).
When going to the internal /usr/lib directory then there are tons of 3rd party libraries. In the past it already caused some problems if there is a newer libstdc++ library than on your system. So, it would be interesting to see what happens when you extract the AppImage, remove the libstc++ library and start the "freecad" executable.
Giulio Buccini
wmayer wrote: Mon Feb 06, 2023 5:39 pmSo, it would be interesting to see what happens when you extract the AppImage, remove the libstc++ library and start the "freecad" executable.
I have extracted the Appimage.
Did you meant the lib named libstdc++ ? Yes? (located in /usr/share/licenses/libstdc++)
I have to put all back in an appimage file to run after deleting that lib?
Opssss! I meant the files:
./usr/lib/libstdc++.so.6.0.30
I should delete them all?
Assuming you have extracted it to /tmp/freecad then you should remove from /tmp/freecad/usr/lib the file libstdc++.so, libstdc++.so.6 and libstdc++.so.6.0.30. This will cause the application to load your system libstdc++ file instead.
You can but you don't have to. Just open a terminal and change to /tmp/freecad. From there run the script AppRun with
./AppRun
Giulio Buccini
[EDIT] I deleted my previous answer.
I cancelled those 3 files. now he cannot find GLIBCXX_3.4.26:
giulio@ubu:~/appimages/appimage-extract/squashfs-root$ ./AppRun
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libFreeCADGui.so)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libFreeCADApp.so)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libFreeCADBase.so)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libQt5Widgets.so.5)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libQt5Widgets.so.5)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.28' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libQt5Widgets.so.5)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libQt5Gui.so.5)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libQt5Core.so.5)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libQt5Core.so.5)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.28' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libQt5Core.so.5)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.13' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libQt5Core.so.5)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/./libboost_regex.so.1.74.0)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.28' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/./libQt5Xml.so.5)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/./libQt5Xml.so.5)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/./libQt5Xml.so.5)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/./libshiboken2.cpython-310-x86_64-linux-gnu.so.5.15)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/./libQt5Network.so.5)
/home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/././libQt5Qml.so.5)
Giulio Buccini
If I put those 3 files back then I get "Segmentation Fault" as before:
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x354c0) [0x7fb7e54f14c0]
#1  /lib/x86_64-linux-gnu/libc.so.6(wcslen+0) [0x7fb7e5567dc0]
#2  /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libpython3.10.so.1.0(+0x1513ae) [0x7fb7e6fe53ae]
#3  /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/../lib/libpython3.10.so.1.0(+0x1e616e) [0x7fb7e707a16e]
#4  /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad(+0x5471) [0x559e0658c471]
#5  /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fb7e54dc840]
#6  /home/giulio/appimages/appimage-extract/squashfs-root/usr/bin/freecad(+0x6c29) [0x559e0658dc29]
