create mounting holes?
ronyd
Post by ronyd »
I created a round case for holding a piezo transducer (see attached pic). I would like to create a round lid with a mount hole (ie.,tabs) on each side. The lid will fit into the case, using mounting holes for a nut and bolt.
Do i create a round part with another part?? for the mounting tabs?
Screen Shot 2023-02-04 at 12.20.44 PM.png (39.97 KiB) Viewed 695 times
Shalmeneser
Re: create mounting holes?
Post by Shalmeneser »
File / Full info / Drawing of your idea ?
No pain no gain.
ronyd
Post by ronyd »
Shalmeneser wrote: Sat Feb 04, 2023 5:39 pm File / Full info / Drawing of your idea ?
No pain no gain.
Also mounts could also be square if it makes it easier to design.
thankx very much
Piezo Case.png (190 KiB) Viewed 643 times
Piezo-case.FCStd
(13.69 KiB) Downloaded 8 times
Shalmeneser
1) Full version info (follow link in red banner).
2) Do not sketch upon face : TNP
:idea:
Piezo-case_SHALM.FCStd
(36.82 KiB) Downloaded 9 times
Capture d’écran 2023-02-04 191253.jpg (37.1 KiB) Viewed 616 times
ronyd
Post by ronyd »
Shalmeneser wrote: Sat Feb 04, 2023 6:14 pm 1) Full version info (follow link in red banner).
:idea:
oooooh i see now, you don't attach mounting part to the edge but too the center of the lid. i overthink and get to complicated...
thankx for taking time out... :!:
ron
papyblaise
Post by papyblaise »
you have intelligently placed the open face on the XY plane, so it is easier to place the sketch of the ear on this plane without risk of TNP
Piezo-case PPB.FCStd
(27.61 KiB) Downloaded 11 times
Piezo-case PPB.JPG (20.68 KiB) Viewed 499 times
Shalmeneser
:idea:
Je dirais même plus.
Piezo-case_SHALM2.FCStd
(29.47 KiB) Downloaded 6 times
ronyd
Post by ronyd »
Shalmeneser wrote: Sat Feb 04, 2023 8:24 pm :idea:
Hi, still learning and great to learn by example. one more object i wanted to add to the case. I need to hole (rectangular) from the case in order to route wire from the case.
I tried using subtractive box? But doesn't extend through the case... Do i need to create a sketch for the box? No sure if I'm on the right thinking here.
thankx
Piezo Case-with-wiring-outlet.png (199.47 KiB) Viewed 379 times
Piezo-case_SHALM2-box-notch.FCStd
(34.72 KiB) Downloaded 4 times
papyblaise
change the Y from 15 to 14mm
Shalmeneser
In your last file, you should not use the solid for support : TNP
Do you need a Hole feature or just a Pocket ?
I usually don't use Primitive from PartDesign but sketch instead.
Piezo-case_SHALM3.FCStd
(46.07 KiB) Downloaded 7 times
Capture d’écran 2023-02-05 184641.jpg (39.22 KiB) Viewed 321 times
