Flat surface creation
Good day
How can I create a flat surface bridging the two surfaces at either end? As you can see, I tried, but to no avail, since I cannot apply thickness.
- STAR6A.PNG (226.18 KiB) Viewed 764 times
- STAR6B.PNG (214.8 KiB) Viewed 764 times
- Star 007.FCStd
- (447.13 KiB) Downloaded 17 times
Re: Flat surface creation
Locale: English/South Africa (en_ZA)
* A2plus
* BIM
* CurvedShapes
* Curves
* Dracula 0.0.2
* ThreadProfile
- STAR6C.PNG (39.43 KiB) Viewed 755 times
Strange definition of "flat surface".
Surface in FreeCAD is something infinite, and usually it is not even a solid.
a Face could be extruded but foillowing Topology a Face is a "limited portion" of a Surface.
See maybe, if it could help:
https://github.com/onekk/freecad-doc/tr ... nographies Topology PDF file, it is a try to explain things.
Thickness exist in FreeCAD but is a rather delicate operation, as it usually broke, as what you think is easy when seen from a mathematical point of view have some problems that are difficult to solve.
But is a mere question of word.
Did you see "Curves WB"?
It has many useful tools to create "surfaces" and work on them.
https://wiki.freecad.org/Curves_Workbench
Hope it helps.
Hope it helps.
A Ruled surface, between two coplanar curves usually works, but sadly not other clues, as I model using scripting so not more experience with GUI.JussyAD wrote: ↑Sat Feb 04, 2023 3:19 pmThanks, Carlo. I used the Curves WB and I thought the Blend tool was my best bet but apparently not. Close but no cigar!
I can generate a surface or face but it has some curvature in an undesired plane. I need it to be coplanar in its local coordinate system.
There are something strange here, offset cannot works well.
- Capture.JPG (12.17 KiB) Viewed 693 times
use approximation with joincurve avoid that. then facebinder of exterior faces and offset3D instead thickness feature.
sorry, the file is about 3Mo.
- Capture.JPG (73.2 KiB) Viewed 519 times
Thank you. It looks perfect. If the file is too large to attach here, please use we transfer and share the link here. Will be much appreciated.
