Restraint by Coordinates (X-Z)
ChipsNChips
Post by ChipsNChips »
I have a disc shaped part on the X-Y plane, 7" diameter and 0.5" thick. I want to subtract a round groove, 1/2" from the OD on one of the flat sides of that disk. The groove's cross section will be part of a circle. I need to sketch a circle in the X-Z (or Y-Z) plane to do this with the groove tool. It's center needs to be 3.25" to the right and 0.53" above the origin. If I add constrained lines from the origin to that point to locate the center of the circle, the groove tool assumes they are part of the groove and the center of my disk is removed along with the desired groove. And if I erase the lines after drawing the circle, then the circle disappears.
So how can I locate a circle on the X-Z plane with it's center at those coordinates? I have looked but nothing seems obvious.
Bance
Re: Restraint by Coordinates (X-Z)
Post by Bance »
Please read and follow the posting rules. http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
ChipsNChips wrote: Sat Feb 04, 2023 11:33 amIf I add constrained lines from the origin to that point to locate the center of the circle
Why would you do that? Is not sufficient to constrain the centre of the circle?
A sketcher reference for you.
https://wiki.freecadweb.org/Sketcher_reference
papyblaise
Post by papyblaise »
you have 2 solutions
1st rapid: you place the center of the disc where the center of the groove will be
2em: you draw the profile of the groove in a plane perpendicular to its position, and you draw a line vertically in the center of the groove which will be the axis of ref
grove.FCStd
(27.91 KiB) Downloaded 12 times
Shalmeneser
Post by Shalmeneser »
Do you need a groove ?
Where is your file with your problem ? It's quicker for us just to modify your file (and sometime find other errors or bad way).
ChipsNChips
I have to stop working so late at night. I simply could not make this work at 5 AM. My bad!
So, I opened FreeCAD and made one more try at it and everything worked perfectly. I started a new sketch on the X-Z plane and drew a circle. I choose the origin and the center of that circle and applied horizontal and vertical constraints. No problem. I constrained the diameter of the circle and everything was fully constrained.
Went to the Parts Design workbench and selected the Groove tool. The exact groove I wanted appeared with no further steps.
It couldn't be easier. And I have no idea why the exact same thing did not work last night. OK, it probably wasn't the exact same thing. Like I said, my bad!
I really must stop working so late. My apologies for the unnecessary question. And I assume the comment about reading the posting rules referred to the lack of photos or the file. I will remember that.
Bance
Post by Bance »
ChipsNChips wrote: Sun Feb 05, 2023 6:24 am I will remember that.
Equally important (though perhaps not this particular instance,) is version information as described.
OS: Manjaro Linux (XFCE/xfce)
Version: 0.21.0.31709 (Git) AppImage
Hash: e188802ca6997d2564e7570ab648462e6a059f87
  * Curves 0.6.6
  * fasteners 0.4.54
  * dodo 1.0.0
  * A2plus 0.4.60i
  * sheetmetal 0.2.61
  * fcgear 1.0.0
  * AirPlaneDesign 0.4.0
  * CurvedShapes 1.0.4
  * DynamicData 2.46.0
  * kicadStepUpMod 10.17.1
  * Plot 2022.4.17
  * Nodes 0.1.36
  * BOLTSFC 2022.11.5
  * BIM 2021.12.0
