Arch Parts.
andrecaldas
Arch Parts.
Post by andrecaldas »
I am really, really new to FreeCAD.
I am trying to model a building (a house). Many times I wonder what is the recommended / best practice / proper way to do things. I am no civil engineer or architect.
I'd like to define some "compound structure" (CBE in the attached file). It is a column over a concrete block, over a concrete "stick" that fills a hole drilled on the ground (I don't know the technical term... a "stake"?).
Now, I'd like this structure to be cloned and "snapped" in wall corners and "T" junctions. I would love if this could happen without me having to carefully place it on the precise location inside the wall. What is the proper / nicer / better (best practice) / full megazord way to do that?
OS: Debian GNU/Linux bookworm/sid (GNOME/gnome)
Version: 0.20.1.
Locale: C/Default (C)
  * parts_library
  * AnimationFreeCAD 1.0.0
  * dodo 1.0.0
  * BIM 2021.12.0
  * Reinforcement
partes.FCStd
(167.72 KiB) Downloaded 31 times
andrecaldas
Re: Arch Parts.
I have added a "WallGuide" sketch to serve as a guide when placing the column.
But I would really like it if it snapped and moved along when the wall gets changed.
In a certain way, I would like WallGuide's points to work as "anchors" to be attached to points in Wall, where the column is placed.
partes.FCStd
(159.21 KiB) Downloaded 32 times
paullee
Re: Arch Parts.
Post by paullee »
Moved to Arch forum for more exposure.
