Sketch of sheetmetal face to position holes
ozindfw
Post by ozindfw »
Freecad newbie.
I'm trying to add some holes to a sheetmetal part. I'm using https://wiki.freecad.org/SheetMetal_SketchOnSheet as my guide.
My problem is that I do not see how to get a sketch of the selected face to work with. If I select the fact and go to the sketcher wb and select new sketch I get a dialog that seems to make sense "Select the method to attach this sketch to the selected object." Flatface or InertalCS The sketch is grayed out in the tree view. The sketch does not seem to have any features from the selected face.
I was expecting to see at least a rectangle or construction lines that I could use to constrain hole positions. It looks like all I may be getting is a sketch plane, and it's not even clear it's locked to the coordinates of the part.
And why is in grayed out in tree view even if I have a feature drawn on it?
What am I missing here? (besides a clue)
I know I could use the partdesign hole tool, but I still need a sketch to apply it.
  * Assembly4 0.12.5
  * ExplodedAssembly
  * fasteners 0.4.54
  * kicadStepUpMod 10.17.1
  * Manipulator 1.5.0
  * sheetmetal 0.2.61
HV_Cover_Bracket.FCStd
(22.69 KiB) Downloaded 17 times
Shalmeneser
Re: Sketch of sheetmetal face to position holes
Post by Shalmeneser »
You need to have something inside your body to put a sketch on it.
I do all SheetMetal directly inside the body but you can also move your last action inside the body -> BaseFeature.
HV_Cover_Bracket_SHALM.FCStd
(27.38 KiB) Downloaded 16 times
Capture d’écran 2023-02-04 082730.jpg (46.36 KiB) Viewed 530 times
ozindfw
Post by ozindfw »
Clearly there is something about FreeCAD states I do not understand.
Screenshot 2023-02-04 094606.png (125.8 KiB) Viewed 464 times
papyblaise
Post by papyblaise »
2 options:
1st: you start with a body, do the 1st sketch in this body, the basebend in the body (with the Sheemetal workshop and the 2 bends
then the hole and pocket sketch
2nd: you introduce your bar angle in the body as a base feature
Note: you can do the 2 bends in the same operation if they are identical and in the same direction
ozindfw wrote: Sat Feb 04, 2023 3:48 pm Clearly there is something about FreeCAD states I do not understand.
What you have Bend001 that are in the Body tree.
In this sense FreeCAD is telling you this.
You could not sketch on this, also You could not sketch on a face, due to the TNP:
TNP Problem
https://wiki.freecadweb.org/Topological_naming_problem
TNP mitigation
https://wiki.freecadweb.org/Feature_edi ... ble_models
You could subtract something (make a hole) from a solid if the solid is existing, the body is empty so "no solid" were the Feature could work on:
See maybe:
3D modelling link and paradigm explained
https://forum.freecadweb.org/viewtopic.php?f=8&t=47493
Part Design WB
https://wiki.freecadweb.org/PartDesign_Workbench
Part Design "feature driven design" concepts
https://wiki.freecadweb.org/Feature_editing
Basic Attachment Tutorial
https://wiki.freecadweb.org/Basic_Attachment_Tutorial
Sketcher constraints
https://wiki.freecadweb.org/Sketcher_scripting
Expressions
https://wiki.freecadweb.org/Expressions
Hoping that will help you to guess something useful.
Shalmeneser
:idea:
HV_Cover_Bracket_SHALM2.FCStd
(35.22 KiB) Downloaded 10 times
Capture d’écran 2023-02-04 185319.jpg (31.39 KiB) Viewed 389 times
