Path to FeaturePython with PropertyFile
If I have created a FeaturePython with a Property of "App::PropertyFile" how do I obtain the Path to the file?
I assume it is one of the main FreeCAD calls.
Re: Path to FeaturePython with PropertyFile
It is not available as a property of DocumentObject?keithsloan52 wrote: ↑Sat Feb 04, 2023 12:24 am If I have created a FeaturePython with a Property of "App::PropertyFile" how do I obtain the Path to the file?
Well it has created one, I assume it creates a file in the same directory that will be used when the freecad file is saved as a zip Fc? No?
Looking at property App::PropertyFileInclude https://wiki.freecad.org/FeaturePython_ ... leIncluded
I think it might be getDocTransientPath().
I will try when I get back to hotel this evening.
From what I know, it usually reuse the last path, or probably the Home dir of the user, if you don't specify one, there is also a preference in Preferences, reachable withkeithsloan52 wrote: ↑Sat Feb 04, 2023 8:31 am Well it has created one, I assume it creates a file in the same directory that will be used when the freecad file is saved as a zip Fc? No?
print(FreeCAD.ParamGet("User parameter:BaseApp/Preferences/General").GetString('FileOpenSavePath'))
FreeCAD.ParamGet("User parameter:BaseApp/Preferences/General").SetString('FileOpenSavePath', "<Your Desired Path>")
keithsloan52 wrote: ↑Sat Feb 04, 2023 8:44 am Looking at property App::PropertyFileInclude https://wiki.freecad.org/FeaturePython_ ... leIncluded
DOC.getPropertyByName('FileName')
DOC.getPropertyByName('TransientDir')
But I have tested them only on "standard objects" and not FeaturePython Objects.
Hope it helps.
App::PropertyFile and App::PropertyFileIncluded are quite different. You should not mix them up. Which are we talking about?
I know that, but the FileIncluded Doc mentioned getDocTransientPath() App::PropertyFile does not mention anything about where the file can be found.
I am trying to create a PythonFeature which has a property that has a File, that will get saved when the Object gets saved and I can add code to drive an external editor to edit the file.
York uses FileIncluded in the Arch workbench but think the usage is different
This will save a Txt file that I use as example to add "documentation" to a FCStd file, it is visible in when you open a FCStd document.keithsloan52 wrote: ↑Sat Feb 04, 2023 5:28 pmI know that, but the FileIncluded Doc mentioned getDocTransientPath() App::PropertyFile does not mention anything about where the file can be found.
info_txt = '''
Text file with new lines that
is saved in the final FCStd doc.
txt_doc = out_doc.addObject("App::TextDocument","Text document")
txt_doc.Label = "Documentation"
txt_doc.Text = info_txt
viewtopic.php?t=38201
and
Embedding other files in: https://wiki.freecad.org/File_Format_FCStd
Hope it helps.
Well if I use App::PropertyFile then I can achieve the desired functionality between the new OpenSCAD objects and an external editor (Emacs)
but the file is not saved with the FreeCAD file.
If I try App::PropertyFileIncluded then the file does not stay around long enough for me to use with an external editor.
A prototype replacement for the OpenSCAD work bench is at https://www.dropbox.com/scl/fo/m00vb2be ... 6o4gblubpo
The relevant source is OpenSCADFeatures.py class definition class SCADObject
External editor is hard coded EMACs on MacOS
Communication with Emacs uses pipes.
