Firstly,
OS: Linux Mint 21 (X-Cinnamon/cinnamon)
Version: 0.21.0.31765 (Git)
Build type: Unknown
Hash: d33005d14e73fdfcc94cc5bd131c578339aa3b8a
Python 3.10.6, Qt 5.15.3, Coin 4.0.1, Vtk 9.1.0, OCC 7.5.1
* toSketch 1.0.1
* toSketch.backup1675442209.7464736 1.0.1 (Disabled)
17:22:14 QFSFileEngine::open: No file name specified
17:24:37 Traceback (most recent call last):
File "/home/matt/.local/share/FreeCAD/Macro/test2.FCMacro", line 7, in <module>
import SplitFeatures
File "/usr/lib/python3/dist-packages/shiboken2/files.dir/shibokensupport/__feature__.py", line 142, in _import
<class 'ModuleNotFoundError'>: No module named 'SplitFeatures'
Shiboken2Config: Using default python: .cpython-310-x86_64-linux-gnu
Found PythonInterp: /usr/bin/python3.10 (found suitable version "3.10.6", minimum required is "3")
CMake Warning (dev) at /usr/share/cmake-3.22/Modules/FindPythonInterp.cmake:171 (mark_as_advanced):
Policy CMP0102 is not set: The variable named "PYTHON_EXECUTABLE" is not in
the cache. This results in an empty cache entry which is no longer created
when policy CMP0102 is set to NEW. Run "cmake --help-policy CMP0102" for
policy details. Use the cmake_policy command to set the policy and
suppress this warning.
Call Stack (most recent call first):
/usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2/shiboken_helpers.cmake:318 (find_package)
/usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2/Shiboken2Config.cpython-310-x86_64-linux-gnu.cmake:44 (shiboken_find_required_python)
/usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2/Shiboken2Config.cmake:5 (include)
cMake/FreeCAD_Helpers/SetupShibokenAndPyside.cmake:22 (find_package)
CMakeLists.txt:76 (SetupShibokenAndPyside)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning (dev) at /usr/share/cmake-3.22/Modules/FindPythonLibs.cmake:277 (mark_as_advanced):
Policy CMP0102 is not set: The variable named "PYTHON_DEBUG_LIBRARY" is not
in the cache. This results in an empty cache entry which is no longer
created when policy CMP0102 is set to NEW. Run "cmake --help-policy
CMP0102" for policy details. Use the cmake_policy command to set the
policy and suppress this warning.
/usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.15.2/shiboken_helpers.cmake:319 (find_package)
CMake Warning (dev) at /usr/share/cmake-3.22/Modules/SelectLibraryConfigurations.cmake:47 (set):
Policy CMP0126 is not set: set(CACHE) does not remove a normal variable of
the same name. Run "cmake --help-policy CMP0126" for policy details. Use
the cmake_policy command to set the policy and suppress this warning.
For compatibility with older versions of CMake, normal variable
"PYTHON_LIBRARY_DEBUG" will be removed from the current scope.
/usr/share/cmake-3.22/Modules/FindPythonLibs.cmake:295 (SELECT_LIBRARY_CONFIGURATIONS)
CMake Warning (dev) at /usr/share/cmake-3.22/Modules/SelectLibraryConfigurations.cmake:77 (mark_as_advanced):
Policy CMP0102 is not set: The variable named "PYTHON_LIBRARY_RELEASE" is
not in the cache. This results in an empty cache entry which is no longer
Found PythonLibs: /usr/lib/x86_64-linux-gnu/libpython3.10.so (found suitable version "3.10.6", minimum required is "3")
SHIBOKEN_PYTHON_INCLUDE_DIRS computed to value: '/usr/include/python3.10'
SHIBOKEN_PYTHON_LIBRARIES computed to value: ''
libshiboken built for RelWithDebInfo
PYTHON_CONFIG_SUFFIX: .cpython-310-x86_64-linux-gnu
PySide 5.15.2 Python module found at /usr/lib/python3/dist-packages/PySide2.
Shiboken: not found
The process for the recompile was
- in folder freecad-source:
git pull
- in folder freecad-build:
cmake ../freecad-source
Any suggestions? It had been working until I did the git pull. I don't believe there were any installs/uninstalls on my system that would have affected this but if there's a way to check I'd be happy to do so.
TIA,
mconsidine
