[Solved] Two lines intersection point
jfc4120
Post by jfc4120 »
  * Help 1.0.3
I found the post viewtopic.php?style=1&p=171776
But they never showed how to get the x,y,z coordinates of the intersection.
I tried
import DraftGeomUtils
s = FreeCADGui.Selection.getSelection()
L1 = s[0]
L2 = s[1]
v = DraftGeomUtils.findIntersection(L1.Shape.Edges[0],L2.Shape.Edges[0])
print(v.x)    # just to test
But that wasn't it. How do I get the actual coordinates? Thanks.
mario52
Re: Two lines intersection point
Post by mario52 »
Hi
complement:
>>> L1 = s[0]
>>> L2 = s[1]
>>> v
[Vector (-1.3432017072221727, 0.28294823146762915, 0.0)]
>>> v[0]
>>> v[0].x
-1.3432017072221727
>>> v[0].y
0.28294823146762915
>>> v[0].z
0.0
>>> # Gui.Selection.clearSelection()
mario
jfc4120
Post by jfc4120 »
@mario52 when I test print:
L1 = s[0]
L2 = s[1]
print(v[0].x)
I get this error:
File "C:/Users/Owner/AppData/Roaming/FreeCAD/Macro/line_intersect_test.py", line 25, in <module>
print(v[0].x)
<class 'IndexError'>: list index out of range
Edit:
File attached:
Edit2:
In console I get:
>>> L1 = s[0]
>>> L2 = s[1]
>>> v
angle_test22.FCStd
(5.63 KiB) Downloaded 23 times
mario52
Post by mario52 »
Hi
your lines hare not intersected (superposed)
this is other thing
mario
jfc4120
Post by jfc4120 »
I am trying to figure out the point where the intersection is.
edwilliams16
Post by edwilliams16 »
>>> help(DraftGeomUtils.findIntersection)
Help on function findIntersection in module draftgeoutils.intersections:
findIntersection(edge1, edge2, infinite1=False, infinite2=False, ex1=False, ex2=False, dts=True, findAll=False)
    Return a list containing the intersection points of 2 edges.
    You can also feed 4 points instead of `edge1` and `edge2`.
    If `dts` is used, `Shape.distToShape()` is used, which can be buggy.
If you use
you get a list of selection objects. If you pick two lines, you get two objects, each an edge. If you select two edges of a single object, you only get one selection object. The two edges are sub-objects of that object and are not accessible.
To access sub-object selections you need Gui.Selection.getSelectionEx(), and to deal with a selection being either the entire object or a subobject, you can do the following:
subObjs = []# create list of selected (sub) objects
for sel in Gui.Selection.getSelectionEx():
  for path in sel.SubElementNames if sel.SubElementNames else ['']:#the else clause handles the case the entire object is selected
      subObj = sel.Object.getSubObject(path)
      subObjs.append(subObj)
      print(f'{sel.Object.Name} {path} ')
      # do stuff with your selections, like
      if subObj.ShapeType == 'Vertex':
          print(f'Vertex Loc = {sub.Point}')
#do stuff with your list, like
edges = [sub for sub in subObjs if sub.ShapeType == 'Edge']
if len(edges) == 2:
    xns = DraftGeomUtils.findIntersection(edges[0],edges[1], findAll = True)
    if xns:
        for xn in xns:
            print(f'Edge intersection at ({xn.x}, {xn.y}, {xn.z})')
    else:
        print(f'Edges do not intersect')
else:
    print(f'Select two edges')
if you replace Gui.Selection.getSelectionEx() with Gui.Selection.getSelectionEx('',0), data is returned in the global coordinate system instead of the local one (or more precisely, the local coordinate system of the linked object, if it is a link).
jfc4120
Post by jfc4120 »
@edwilliams16 I keep getting
16:35:04 Line001 Edge1
16:35:04 Line Edge1
16:35:04 Edges do not intersect
I am after the point they would intersect.
mario52
Post by mario52 »
Hi
aloha edwilliams16, good
jfc4120 with your example file (angle_test22.FCStd):
L1 = s[0]
L2 = s[1]
v = DraftGeomUtils.findIntersection(L1.Shape.Edges[0],L2.Shape.Edges[0], infinite1=True, infinite2=True, ex1=False, ex2=False, dts=True, findAll=False)
print(v)
#result [Vector (-543.56428337233, -4.0574187284443696e-16, -903.1914471949784)]
mario
edwilliams16
jfc4120 wrote: Fri Feb 03, 2023 10:36 pm @edwilliams16 I keep getting
16:35:04 Line Edge1
I quoted the help on DraftGeomUtils.findIntersection for two reasons
  • So you learn how to answer your own question on how to get the locations
  • To point out it that has options.
If you want to find where the extended edges intersect, you need the options:
xns = DraftGeomUtils.findIntersection(edges[0],edges[1], infinite1=True, infinite2=True, findAll = True)
without that you only get those of the actual edges. Note that this routine does not assume the edges are straight lines. That is why there might be more than one. Try a circle and intersecting line, for instance.
jfc4120
Post by jfc4120 »
@edwilliams16 works great. I will test more.
