[Solved] Two lines intersection point
Re: Two lines intersection point
jfc4120 wrote: Fri Feb 03, 2023 11:54 pm @edwilliams16 works great. I will test more.
If you are sure that lines are intersecting, you could use directly:
obj.intersect(obj2, tol)
By memory but as usual:
help(Part.Shape.intersect)
Will give you more hint.
I use it very frequently in code and is very handy, but has not "infinite" options.
jfc4120
Re: [Solved] Two lines intersection point
Post by jfc4120 »
@onekk I punched it in and got:
AttributeError: type object 'Part.Shape' has no attribute 'intersect'
jfc4120 wrote: Sat Feb 04, 2023 6:18 pm ...
Sorry.
But you have been warned, don't trust on my memory. :lol:
Let me check now that I have a computer:
help(Part.LineSegment.intersect)
help(Part.Circle.intersect)
Help on method_descriptor:
intersect(...)
    Returns all intersection points and curve segments between the curve and the curve/surface.
                    arguments: curve/surface (for the intersection), precision (float)
but also:
.intersect2D
.intersectCC
.intersectCS
Tolerance could play a relevant role between fails and success, usually I use 0.0001 in mm that is a reasonable "machining precision" but sometimes, even 0.001.
As example:
20230205-intersect.py
(1.02 KiB) Downloaded 13 times
Hope it helps.
jfc4120
Post by jfc4120 »
@onekk thanks I will give it a try.
