Sheetmetal workbench: Engineering mode is not enabled.
drmacro
Post by drmacro »
What does this warning mean when you click unfold in Sheetmetal workbench? :?:
Syres
Re: Sheetmetal workbench: Engineering mode is not enabled.
Post by Syres »
As far as I can tell it's just a manually added preference that saves/doesn't save the K-factor, the preference is held in:
def engineering_mode_enabled():
    FSParam = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/SheetMetal")
    return FSParam.GetInt("EngineeringUXMode", 0)  # 0 = disabled, 1 = enabled
and the 'decision' is made in this code:
            if engineering_mode_enabled():
              # do nothing, user should explicitly select the K-Factor
              # see https://github.com/shaise/FreeCAD_SheetMetal/pull/79#issuecomment-487774249
              # Neither MDS nor virtual material is defined. Uncheck the MKF checkbox:
              self.checkKfact.setChecked(False)
            else:
              self.checkKfact.setChecked(True)
