Toolbar icons disappear
Re: Toolbar icons disappear
I have no issues with the icons. But I see this error message when editing "Frame Sketch":
06:42:27  Traceback (most recent call last):
  File "<string>", line 12, in <module>
  File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Show/mTempoVis.py", line 443, in sketchClipPlane
    editDoc = Gui.editDocument()
<class 'NameError'>: name 'Gui' is not defined
06:42:27  ViewProviderSketch::setEdit: visibility automation failed with an error:
OS: macOS 13.0
Version: 0.21.0.31709 (Git)
Hash: e188802ca6997d2564e7570ab648462e6a059f87
Locale: C/Default (C)
  * FC_SU
  * DynamicData 2.46.0
  * freecad.gears 1.0.0
  * FeedsAndSpeeds 0.5.0
  * dxf-library
  * fcgear 1.0.0
  * fasteners 0.4.54
  * sheetmetal 0.2.60
  * ExplodedAssembly
  * Curves 0.6.6
You have 24 dimensions in your sketch which you may not really need all. Using geometric constraints instead can be advised.
This part of the sketch looks rather cumbersome, especially the selected dimensions seems rather arbitrary. Seeing the expression I rather guess it should be the difference between the radii. There are similar things on the left.
Here is a proposal where I have reduced the number of dimensions to 10.
PartHolder_cb.FCStd
(22.49 KiB) Downloaded 45 times
Shalmeneser
Post by Shalmeneser »
:idea:
7 dimensions but
don't know if big and small arcs have the same center (+1 dimension otherwise)
don't know if round corner is always tangent (+1? dimension otherwise)
fillet forgetten (+1)
Parametric Part Holder _SHALM.FCStd
(38.96 KiB) Downloaded 43 times
Capture d’écran 2023-02-07 100647.jpg (56.31 KiB) Viewed 585 times
jenkins007
Post by jenkins007 »
Thank you. Am still learning this system. The frame sketch is not finished and should have been removed, but was using it as the example.
I reset preferences, and I have yet to see the error.
As far as all the constraints, thank you. This is a parametic toolbox drawer dependent on the PLA spool size, which varies by vendor. I will adjust using your constraints, instead of the plethora that I used.
