Guitar Neck
dickelec
Guitar Neck
Post by dickelec »
I have created this Telecaster style neck in FreeCAD, generated the gcode and machined it on my CNC router. It is not perfect, particularly around the upper reaches of the neck to head transition, but nothing that cannot be rectified with a little sanding.
It is my first proper project and it has taken me a while to reach this stage and I'm sure my FreeCAD files contain numerous inefficiencies and school-boy errors nevertheless I am delighted with the result. I have machined several necks in cheap wood before getting to this stage and I am about to commit the design to moderately expensive maple.
The design is spread over three files, NeckMaster has the basic shapes along with partly formed head and heel. NeckBack links elements of the NeckMaster and develops the shaft and head and heal transitions to create the shape in the image above. The gcode is generated here for the back shaping. The last file, imaginatively named NeckOther links the NeckBack component, adds the truss rod slot and generates all the remaining gcode.
In the process of modelling, I suffered numerous frustrations from the topological naming problem. Making even a minor dimensional change often resulted in hours of corrective work. However, I cannot praise FreeCAD enough. It is simply remarkable.
OS: Ubuntu 22.04.1 LTS (KDE/plasma)
Version: 0.21.0.31709 (Git) AppImage
Hash: e188802ca6997d2564e7570ab648462e6a059f87
  * Curves 0.6.5
NeckMast.FCStd
(50.92 KiB) Downloaded 126 times
Neck_FBackShape.FCStd
(890.75 KiB) Downloaded 110 times
NeckOther.FCStd
(976.23 KiB) Downloaded 106 times
dickelec
Re: Guitar Neck
Post by dickelec »
I just realised: I broke the link between the second and last files. Here is the correct Neck_Back file. Apologies for that.
Neck_FBackShapeExp3P.FCStd
(890.75 KiB) Downloaded 120 times
LittleGreyAliens
Re: Guitar Neck
Post by LittleGreyAliens »
Very cool! I would like to see an example photograph once you've machined a neck.
dickelec
Re: Guitar Neck
Post by dickelec »
Here are some photos of the neck, straight off the CNC router. I could not be more pleased.
NCG
Re: Guitar Neck
Post by NCG »
Very Nice! Thank you so much for sharing - I've been working on a neck design in FreeCAD for way too long. Cannot figure out what I'm doing wrong. Perhaps studying your examples will put me on the right path.
mshaynerush
Re: Guitar Neck
Post by mshaynerush »
Okay, I need to know what path tool you used. I probably need to also know what version of FreeCAD because the latest version has no path operation that will cut the back of the neck, or for that matter, any convex curve where the Z axis has to change in an arc path.
Looks great to me.
