Centering ShapeString parametrically
nefarious
Post by nefarious »
I am in the process of learning how to manipulate text in freecad and trying to center shapeString on a solid. I have all of my parameters for the solid in a spreadsheet and I notice that the shapestring has some parameters available. I can show the bounding box in the application but I can't figure out how to add it to an equation to center the text when the string changes. Is this possible?
Re: Centering ShapeString parametrically
nefarious wrote: Fri Feb 03, 2023 6:05 pm I am in the process of learning how to manipulate text in freecad and trying to center shapeString on a solid. I have all of my parameters for the solid in a spreadsheet and I notice that the shapestring has some parameters available. I can show the bounding box in the application but I can't figure out how to add it to an equation to center the text when the string changes. Is this possible?
usually you could retrieve the BoundBox, so probably:
<<Object>>.Shape.BoundBox. will go.
Take in account that BoundBox are unitless so you have to multiply them * 1mm if not it will not work.
In the file attached in Cube001 placement X you will see an example of expression.
test_expression.FCStd
(5.38 KiB) Downloaded 16 times
help(FreeCAD.BoundBox)
will show you parameter other than XLength
Hope it helps
drmacro
Post by drmacro »
You are welcome to try this macro/Python script.
Select the face and an edge to indicate the direction, then run the script.
CenterShapeStringOnFace-1.zip
(5.58 KiB) Downloaded 14 times
