Switching forum and wiki from freecadweb.org to freecad.org
maxwxyz
Re: Switching forum and wiki from freecadweb.org to freecad.org
Post by maxwxyz »
If you add the "web" in the URL the old logo shows up, so it seems to be a modified file I guess?
flachyjoe
Post by flachyjoe »
FYI "Elegance" theme show the FreeCAD logo
Capture d’écran_2023-02-03_22-08-33.png (37.95 KiB) Viewed 2195 times
<img src="./styles/elegance/theme/images/logo.png" data-src-hd="./styles/elegance/theme/images/logo_hd.png" alt="FreeCAD Forum">
- Flachy Joe -
chennes
Post by chennes »
Yeah, that theme has several PNG files in place with our logo -- so it must really be a combination of a setting and having the file in place.
Chris Hennes
Pioneer Library System
david69
Post by david69 »
one observation, impact TBC, on the change of the wiki:
since the 1st of Feb, following minor changes on already translated pages, randomly, html tags are added to pages.
we can determine them by the "over weight" they take, if I can say that.
Capture d’écran du 2023-02-04 14-17-27.png (123.55 KiB) Viewed 2064 times
and in the source code of the translated page, we have this adding:
Capture d’écran du 2023-02-02 10-51-05.2.png (23.7 KiB) Viewed 2064 times
yorik
Post by yorik »
I just noticed there is a "delete cookies" button on the forum itself:
david69 wrote: Sat Feb 04, 2023 3:23 pm one observation, impact TBC, on the change of the wiki:
It might not be because of the domain name change, but because of the wiki version change done a couple of weeks ago. It might be something the mediawiki project decided to add. In any case, it does not seem to cause really a problem, right? At least not a big one... In any case I couldn't find anything on our side that would cause that.
chennes wrote: Fri Feb 03, 2023 9:22 pm Yeah, that theme has several PNG files in place with our logo -- so it must really be a combination of a setting and having the file in place.
Indeed I remember I did that manually for the elegance theme, there didn't seem to be a way to do another way. And the elegance theme was copied over from previous version. The prosilver theme is built-in so we didn't copy over. Thanks for fixing, whoever it was! (@chennes I suppose :) )
obelisk79 wrote: Fri Feb 03, 2023 7:44 pm I'm willing to do the legwork on adapting something like this if the team gives me the greenlight to do so.
Yes please!!! Elegance seems to me the best place to start as it is "similar" in colors to the FreeCAD colors, and it seems well used and supported and has all the useful features (notifications, unread count, etc) but if you have a better idea, including how to add a dark theme, etc, fire away!
david69
Post by david69 »
yorik wrote: Sun Feb 05, 2023 11:38 am it does not seem to cause really a problem, right? At least not a big one...
in term of reading for the moment, no, in term of extra weight of the page (alourdir), it's not minor.
what will be the impact at the end of the day on all the wiki, no idea. ant it is not systematic, why? it's an open question.
if it's the version of mediawiki, can we compare with other wikis using the same version?
maxwxyz
Post by maxwxyz »
On the default template it still displays the "phpBB forum software" logo instead of the FreeCAD logo.
user1234
Post by user1234 »
Could it be, that the the bandwidth is throttled? Since a few day, the forum is really slow. Also i saw, that there a damn much users online (>250). I can imaging, that on a specific amount of traffic per month, the bandwidth will be throttled.
Greetings
user1234
jfc4120
Post by jfc4120 »
I only noticed the "slowness" starting March 17, 2023. Prior to that no problems. I hope it gets fixed.
Perhaps archive real old post. Perhaps they can still be available in an archive database someone can view.
But why all of a sudden the slow down?
yorik
Post by yorik »
Apparently we've been under a DDoS attack. This is now over, and we're looking at what we could do to prevent this in the future.
Also, the FPA is also looking at putting some money in to give more power and bandwidth to the forum and wiki.
