Switching forum and wiki from freecadweb.org to freecad.org
Hi people,
Today with @chennes and @kkremitzki we'll switch the forum and wiki software to use freecad.org instead of freecadweb.org as the main URL.
If all goes well freecadweb.org-based URLs will still work seamlessly, but you might get logged out and need to log in again.
Re: Switching forum and wiki from freecadweb.org to freecad.org
We'll also update the phpbb software. Expect some temporary disruption!
wiki is done and is now using https://wiki.freecad.org as its main URL. https://wik.freecadweb.org URLs still work
Forum is done too, now using https://forum.freecad.org as its main URL instead of https://forum.freecadweb.org. You might need to log in again. freecadweb-based URLs still work
- adrianinsaval
nice! seems to be working fine
Last edited by adrianinsaval on Thu Feb 02, 2023 12:30 pm, edited 1 time in total.
I have to log in each time I open forum.freecad.org - after logging in (with remember me option checked), closing the tab and opening this website again. Even worse - it logs me out when I submit a reply. Is that normal ?
- adrianinsaval
I now noticed that too
Indeed jut noticed it too now
*EDIT* But now it keeps me logged in. Maybe it was a temporary issue...
Okay cookie settings were wrong. Let's see now if it is solved...
Apparently everything is solved, and phpbb software is now updated!
