[Solved] Help with a macro
jfc4120
Re: [Solved] Help with a macro
Post by jfc4120 »
@edwilliams16 and @dan-miel I was curious if I could get mine working, and did, may still tweak more.
I will use the other as well.
Code:
import FreeCAD, FreeCADGui
# -*- coding: utf-8 -*-
import Draft
import math
# from math import cos, sin, radians
from PySide import QtGui
convert = 25.4
TOTAL = 0
getDouble = QtGui.QInputDialog.getDouble
Vector, Placement = App.Vector, App.Placement
doc = App.ActiveDocument
start_point = Vector(0, 0, 0)
RTT, rttflag = getDouble(None, 'example', 'Angle same object enter 1 otherwise enter 2', decimals=0)
#inserted
if RTT == 1 or RTT == 2:
    edge = FreeCADGui.Selection.getSelectionEx()[0].SubObjects[0]
    edgePt1 = edge.Vertexes[0].Point
    edgePt2 = edge.Vertexes[1].Point
    vect = edgePt1 - edgePt2
    #here
    x0 = round( edge.Vertexes[0].Point.x * .039370078, 6)
    y0 = round( edge.Vertexes[0].Point.y * .039370078, 6)
    z0 = round( edge.Vertexes[0].Point.z * .039370078, 6)
    x1 = round( edge.Vertexes[1].Point.x * .039370078, 6)
    y1 = round( edge.Vertexes[1].Point.y * .039370078, 6)
    z1 = round( edge.Vertexes[1].Point.z * .039370078, 6)
    if RTT == 1:
        edge2 = FreeCADGui.Selection.getSelectionEx()[0].SubObjects[1]
    if RTT == 2:
        edge2 = FreeCADGui.Selection.getSelectionEx()[1].SubObjects[0]
    x2 = round(edge2.Vertexes[0].Point.x * .039370078, 6)
    y2 = round( edge2.Vertexes[0].Point.y * .039370078, 6)
    z2 = round( edge2.Vertexes[0].Point.z * .039370078, 6)
    x3 = round( edge2.Vertexes[1].Point.x * .039370078, 6)
    y3 = round( edge2.Vertexes[1].Point.y * .039370078, 6)
    z3 = round( edge2.Vertexes[1].Point.z * .039370078, 6)
    if x0 == x2 and y0 == y2:
        p1 = App.Vector(x0, y0, z0)
        p2 = App.Vector(x1, y1, z1)
        p3 = App.Vector(x3, y3, z3)
    if x0 == x3 and y0 == y3:
        p3 = App.Vector(x2, y2, z2)
    if x1 == x2 and y1 == y2:
        p1 = App.Vector(x1, y1, z1)
        p2 = App.Vector(x0, y0, z0)
    if x1 == x3 and y1 == y3:
    ang1 = math.degrees((p2 - p1).getAngle(p3 - p1))
    print('angle', ang1)
    #good ang2 = math.degrees((p3 - p2).getAngle(p1 - p2))
    #ang2 = math.degrees((p1 - p2).getAngle(p3 - p2))
    #print(ang2)
    #ang3 = degrees((p1 - p3).getAngle(p2 - p3))
    #The side lengths are:
    #Code: Select all
    #L12 = (p1 - p2).Length
    L12 = (p2 - p1).Length
    #print(L12)   this one
    #L23 = (p2 - p3).Length
    #L31 = (p3 - p1).Length
    #pt = App.Vector(multlist[0][0] * convert, multlist[0][1] * convert, multlist[0][2] * convert)
    #t1 = round(ang1, 3)
    #t11 = str(t1)
    #text1 = Draft.make_text(t11, pt)
    #print('p1',p1)
else:
    print("Must enter a 1 or 2")
I haven't figured out yet how to differentiate whether it's from one object (like a wire) or two (2 lines, cube edge) without the input box. I am not that advanced yet.
Edit:
Figured it out by finding another post to get count, changed to:
sel = FreeCADGui.Selection.getSelection()
RTT = len(sel)
print(RTT)  #number of selections
Rest is the same. Mine has to have a vertex, The one from @edwilliams16 the lines don't have to be touching, So I will use his.
But for practice I will continue on mine to see if I can do the same.
Still as short as his code is, I still do not understand it. But I am going to try.
