AttributeError: 'tuple' object has no attribute 'Name'
Moderator: oliveroxtoby
poulmack
Post by poulmack »
I've assigned bcs on the attached model. The wall bc has the thick selected to use as default boundary condition for unselected faces.
I am getting the following error which seems to be related to Python when writing the case
12:34:28  Traceback (most recent call last):
12:34:28    File "C:\Users\Pcaicedo\AppData\Roaming\FreeCAD\Mod\CfdOF\.\CfdOF\Solve\TaskPanelCfdSolverControl.py", line 127, in write_input_file_handler
12:34:28      FreeCADGui.doCommand("writer.writeCase()")
12:34:28    File "<string>", line 1, in <module>
12:34:28    File "C:\Users\Pcaicedo\AppData\Roaming\FreeCAD\Mod\CfdOF\.\CfdOF\Solve\CfdCaseWriterFoam.py", line 119, in writeCase
12:34:28      self.processBoundaryConditions()
12:34:28    File "C:\Users\Pcaicedo\AppData\Roaming\FreeCAD\Mod\CfdOF\.\CfdOF\Solve\CfdCaseWriterFoam.py", line 281, in processBoundaryConditions
12:34:28      face = bc['ShapeRefs'][0].Name
12:34:28  AttributeError: 'tuple' object has no attribute 'Name'
  * Assembly4 0.12.5
  * CfdOF 1.21.3
  * ExtremeProDark 2.6.4
  * Render 2022.4.0
Any help to solve this error will be appreciated.
Thanks,
Paul
3D Model.FCStd
(173.87 KiB) Downloaded 40 times
oliveroxtoby
Re: AttributeError: 'tuple' object has no attribute 'Name'
Post by oliveroxtoby »
poulmack wrote: Wed Feb 01, 2023 7:42 pm Hello,
Should be resolved (should give you a more useful error message now).
