I followed this tutorial: https://wiki.freecadweb.org/Creating_a_ ... th_Part_WB. After I cut the hole in the part, the hole still appears to be "full". It's like it made the cut, but didn't remove the inside of the hole. Pictures of the tutorial image and my image are in the attached document. I also attached the freecad file.
I just updated freecad and I'm on
Version: 0.20.2.29603 (Git) AppImage
On my first attempt, I thought I had it pretty good, but when I went to cut the part on a router, I realized that the main body of the part had no front or back to it - it was just the edge that was extruded.
On the next attempt, I made sure that the main body was a solid with a front, back, and edge, and I seem to have that now. What I cannot figure out is how to make the holes "empty". In fact, I don't even know how to tell whether or not they are empty. If I look at the wireframe I can see all the correct internal structure, but I don't know if there is anything in the holes, or not.
The holes need to be cut very accurately so I would like to avoid having to recreate the holes from scratch. I would like to use the geometry of holes that is already there in the SVG that I started with. The holes are the 6 long slots.
Is this possible?
Lawrence
