C++ Unit testing framework up and running
waebbl
Re: C++ Unit testing framework up and running
Post by waebbl »
wmayer wrote: Tue Feb 07, 2023 9:58 am These are separate executables and a user must run them from the command line in order to see any results. Another thing is that the packages will get quite bloated if each class has its own test executable.
The files wont get installed onto the system. They are just run during the test phase of the build process, often invoked using ctest for a cmake based build system.
waebbl wrote: Tue Feb 07, 2023 6:46 pm The files wont get installed onto the system. They are just run during the test phase of the build process, often invoked using ctest for a cmake based build system.
OK, that makes sense.
berniev
Post by berniev »
A PR is lodged. How does a reviewer/maintainer know the changes a) work, and b) don't change functionality?
Imagine if the PR includes tests
TEST(Unit, FlowCheckThrowPos)
    EXPECT_ANY_THROW(new Base::Unit("test",0,8,0,0,0,0,0,0));
TEST(Unit, GetString){
    Base::Unit unit {"test",0,0,-8,0,0,0,0,0};
    EXPECT_EQ(unit.getString(), "1/s^8");
TEST(Unit, GetStringElectricPotential){
    Base::Unit unit {Base::UnitDefs::ElectricPotential};
    EXPECT_EQ(unit.getString(), "mm^2*kg/(s^3*A)");
TEST(Unit, AsStringElectricPotential){
    EXPECT_EQ(unit.asString(), "Unit: mm^2*kg/(s^3*A) (2,1,-3,-1,0,0,0,0) [ElectricPotential]");
TEST(Unit, NameString){
    EXPECT_EQ(unit.nameStr(), "test");
Without tests, reviewers are understandably cautious.
Tests are what makes fast merging possible (e.g. in C4) because a heavy burden is lifted off the reviewer's back.
chennes
Post by chennes »
Regarding using FetchContent -- according to the cMake documentation, FetchContent_MakeAvailable will use find_package first, and will only attempt to download the code itself if it cannot find it some other way. My understanding of our earlier discussion is that is basically exactly the behavior we want, right? It replicates the idea of having a git submodule, but only if that submodule is actually needed. @berniev I didn't follow the original discussion -- why did you end up removing that from the PR?
Chris Hennes
Pioneer Library System
berniev
Post by berniev »
I don't remember noticing that FetchContent_MakeAvailable will try find_package first. Good spot! I used it because it (from memory) was google's reccommended way.
I did have this in a PR, but while it languished The Boss did a commit sticking with the lib in the project source, so who was I to argue -- we were making progress. The next version was just a tidy-up of the directory structure without changing how the lib gets where it is.
I have no issue if you want to go that way.
berniev
Post by berniev »
This discussion is very relevant to ongoing discussions re fmt library as well.
abdullah
