Issue with Draft SelectPlane
tijtij
Post by tijtij »
I am getting the following error when invoking Draft SelectPlane to set the working pane to a selected face.
Running the Python command 'Draft_SelectPlane' failed:
File "/Applications/FreeCAD Weeekly.app/Contents/Resources/Mod/Draft/draftguitools/gui_selectplane.py", line 138, in Activated
if self.handle():
File "/Applications/FreeCAD Weeekly.app/Contents/Resources/Mod/Draft/draftguitools/gui_selectplane.py", line 215, in handle
FreeCAD.DraftWorkingPlane.alignToFace(sel.SubObjects[0],
File "/Applications/FreeCAD Weeekly.app/Contents/Resources/Mod/Draft/WorkingPlane.py", line 579, in alignToFace
if shape.ShapeType == 'Face':
cannot determine type of null shape
Draft SelectPlane will work again by saving the file, closing the file, and reopening the file. But after modifying the file by adding or moving an object the error will reappear until I reopen the file again.
I'm running macOS arm but I was able to recreate the bug on Windows x86_64. Here is a video of the error. In the video you can see that Draft SelectPlane is working but after adding an object it breaks. Is it possible that my file got corrupted, even though the issue goes away after reopening the file?
error-Draft-SelectPlane.FCStd
(207.3 KiB) Downloaded 34 times
OS: macOS 13.1
Version: 0.21.0.31483 (Git)
Hash: 588620fd9fd138892b1cd2466f5c87d441493174
Python 3.11.0, Qt 5.15.6, Coin 4.0.0, Vtk 9.2.2, OCC 7.6.3
Locale: C/Default (C)
  * BIM 2021.12.0
  * Help 1.0.3
Version: 0.21.0.31709 (Git)
Hash: e188802ca6997d2564e7570ab648462e6a059f87
Python 3.8.15, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Roy_043
Re: Issue with Draft SelectPlane
Post by Roy_043 »
Confirmed. This is caused by the Site object. Workaround: make the Site invisible and then make the House visible again. Or you can remove the Site.
tijtij
Post by tijtij »
Roy_043 wrote: Mon Jan 30, 2023 8:13 am Confirmed. This is caused by the Site object. Workaround: make the Site invisible and then make the House visible again. Or you can remove the Site.
Thanks @Roy_043. I see now how that the Site object ends up getting selected in the tree view even though I clicked on a child object. You have a keen eye to have noticed that.
Should a file a bug report?
Roy_043
Post by Roy_043 »
