Draft is not showing the correct angle dimension
Roy_043
Re: Draft is not showing the correct angle dimension
Post by Roy_043 »
jfc4120 wrote: Sun Jan 29, 2023 7:19 pm Made a wire on 1-2-3, moved the wire over to the right, and it gives the correct angle.
That is understandable as the DraftGeomUtils.findIntersection() function looks for endpoints that exactly match first. In that case it just returns that point without calculating the intersection. If the edges are from a single triangular wire an exact match will be found. With one edge from the sketch and one edge from the wire there is a minute tolerance between the endpoints that apparently match.
Roy_043
Post by Roy_043 »
jfc4120 wrote: Sun Jan 29, 2023 9:08 pm otherwise all is the same.
No, it's not, the coords are different as well. You need to redo your tests. This problem occurs in V0.19 to V0.21.
Roy_043
Post by Roy_043 »
thomas-neemann wrote: Sun Jan 29, 2023 5:39 pm it is also wrong here, but with a different value
With the center being wrong, the resulting angle depends on which endpoint of the edges is used in the calculations.
jfc4120
Post by jfc4120 »
@Roy_043 I also notice that in the previous version and current version that linear dimensions are correct in all views including home view. But angle dimensions are not correct in home view but other views are correct. This is a different test: Attached
The 125.26 is the correct angle.
line_angle7.FCStd
(7.36 KiB) Downloaded 20 times
Roy_043
Post by Roy_043 »
That is a different issue. You need to ensure that the draft working plane is correctly aligned before creating an angular dimension.
jfc4120
Post by jfc4120 »
@Roy_043 Okay going back to the original problem and in current version:
If I make a wire over the lines, including the sketch line, then delete the sketch, The angle from the wire is correct: Attached :roll:
Edit:
All was even with screen as I again used the Align_View_to_Face.FCMacro. But even aligned, a dimension to the sketch line shows wrong, but I know the angle is correct, verified with @edwilliams16 macro and sketcher is correct.
line_angle8.FCStd
(6.25 KiB) Downloaded 20 times
Roy_043
Post by Roy_043 »
I have already explained that. It does not make sense to add more files when the cause of the problem has already been identified.
jfc4120
Post by jfc4120 »
Alright, I will start a new post concerning home view dimensions, since that is a different issue. Thanks
Also will the issue here be corrected soon?
thomas-neemann
Post by thomas-neemann »
Roy_043 wrote: Sun Jan 29, 2023 9:22 pm ....
workaround: draw an additional polyline before dimensioning
angle_test-tn.FCStd
(15.68 KiB) Downloaded 29 times
Roy_043
Post by Roy_043 »
Thanks, but this solution has already been given twice in this topic.
