Draft is not showing the correct angle dimension
jfc4120
Post by jfc4120 »
  * Help 1.0.3
I was just testing out some geometry, and ran across this:
I used the macro: Align_View_to_Face.FCMacro
I also had a sketch where I bisected an angle.
The sketch shows the correct angle of 62.63 degrees.
@edwilliams16 python script he helped me with also show the correct, here is script:
import FreeCAD, FreeCADGui
# -*- coding: utf-8 -*-
import Draft
import math
# from math import cos, sin, radians
from PySide import QtGui
convert = 25.4
TOTAL = 0
getDouble = QtGui.QInputDialog.getDouble
Vector, Placement = App.Vector, App.Placement
doc = App.ActiveDocument
start_point = Vector(0, 0, 0)
selX = FreeCADGui.Selection.getSelectionEx()
PrintMsg = FreeCAD.Console.PrintMessage
PrintMsg("Objects selected:\n")
KOUNT = 0
# added
for sel in selX:
    KOUNT = KOUNT + 1
    v = sel.Object.Shape
    X = v.Point.x * .039370078
    Y = v.Point.y * .039370078
    Z = v.Point.z * .039370078
    if KOUNT == 1:
        multlist = [[X, Y, Z]]
    if KOUNT > 1:
        multlist.append([X, Y, Z])
# added new
p1 = App.Vector(multlist[0][0], multlist[0][1], multlist[0][2])
p2 = App.Vector(multlist[1][0], multlist[1][1], multlist[1][2])
p3 = App.Vector(multlist[2][0], multlist[2][1], multlist[2][2])
#p = App.Vector(multlist[3][0], multlist[3][1], multlist[3][2])
#q = App.Vector(multlist[4][0], multlist[4][1], multlist[4][2])
ang1 = math.degrees((p2 - p1).getAngle(p3 - p1))
print(ang1)
#good ang2 = math.degrees((p3 - p2).getAngle(p1 - p2))
#ang2 = math.degrees((p1 - p2).getAngle(p3 - p2))
#print(ang2)
#ang3 = degrees((p1 - p3).getAngle(p2 - p3))
#The side lengths are:
#Code: Select all
#L12 = (p1 - p2).Length
L12 = (p2 - p1).Length
print(L12)
#L23 = (p2 - p3).Length
#L31 = (p3 - p1).Length
Yet if I dimension the angle in draft mode, it shows the wrong angle, any ideas as of why?
Drawing and images attached:
angle_test2.FCStd
(14.11 KiB) Downloaded 29 times
Re: Draft is not showing the correct angle dimension
From what I know in Sketch you have has no problems as you are working on a 2d plane so no ambiguity here.
Now the rough explanation of weird results.
In 3d you could not get an Angle if you are not specifying a reference axis, probably what you get are differences between normals. I use this to orient shapes using normals of surfaces, but they are normals and should be used incorporating the "object orientation" to obtain a value to correctly pass to a Placement.
Not saying that again relevant code was supplied by @edwilliams16 he and few others are 3d math experts here. :D
Sadly I'm not skilled enough to explain the math and relevant concepts behind.
Roy_043
Post by Roy_043 »
Confirmed. I'll move this to the Draft forum.
Version: 0.21.0.31641 (Git)
Hash: d28d63b87b60161419c6c0c532fbbfaed96926b8
Roy_043
Post by Roy_043 »
The problem is caused by the wrong calculation of the center of the angle. DraftGeomUtils.findIntersection() fails due to tolerance issues. Normal vectors that have an almost zero length because of rounding errors are used.
import DraftGeomUtils
from FreeCAD import Vector
DraftGeomUtils.findIntersection(Vector(459.0638313293458, 5.684341886080802e-14, -16.121107101440856),
                                Vector(967.0638313293464, 508.0000000000001, 491.87889289855923),
                                Vector(459.0638313293458, 6.927791673660977e-14, -16.121107101440902),
                                Vector(27.052353974566813, 590.1940314391262, 574.0729243376869),
                                True,
                                True)
thomas-neemann
Post by thomas-neemann »
jfc4120 wrote: Sun Jan 29, 2023 7:41 am ...
it is also wrong here, but with a different value
angle_test2-tn.FCStd
(13.88 KiB) Downloaded 24 times
Version: 0.21.0.31709 (Git) AppImage
Hash: e188802ca6997d2564e7570ab648462e6a059f87
  * Curves 0.6.5
Roy_043
Post by Roy_043 »
Roy_043 wrote: Sun Jan 29, 2023 12:45 pmDraftGeomUtils.findIntersection() fails due to tolerance issues.
It not (just?) a tolerance issue. Even if I move the points so that there is no longer a coincident point there is a problem.
pt1 = Vector(459.0638313293458, 5.684341886080802e-14, -16.121107101440856)
pt2 = Vector(967.0638313293464, 508.0000000000001, 491.87889289855923)
pt3 = Vector(459.0638313293458, 6.927791673660977e-14, -16.121107101440902)
pt4 = Vector(27.052353974566813, 590.1940314391262, 574.0729243376869)
delta12 = pt2 - pt1
delta34 = pt4 - pt3
pta = pt2
ptb = delta12 + pt2
ptc = pt4
ptd = delta34 + pt4
print(DraftGeomUtils.findIntersection(pt1, pt2, pt3, pt4, True, True)) # Wrong intersection.
print(DraftGeomUtils.findIntersection(pta, ptb, ptc, ptd, True, True)) # No intersection found.
jfc4120
Post by jfc4120 »
I tried this:
Made a wire on 1-2-3, moved the wire over to the right, and it gives the correct angle. For some reason it doesn't give the correct angle on the sketch line in draft, but in sketcher it does. Attached:
angle_test3.FCStd
(15.73 KiB) Downloaded 22 times
jfc4120
Post by jfc4120 »
Okay this is weird, I duplicated the same in the previous version and got correct results, attached:
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Do I need to install the previous version for now?
line_angle5.FCStd
(8.92 KiB) Downloaded 21 times
Roy_043
Post by Roy_043 »
jfc4120 wrote: Sun Jan 29, 2023 7:52 pm I duplicated the same
I would say the files are similar but different. Your 3rd file does not show the problem in V0.20.2 either. Installing the previous version is not called for I think.
jfc4120
Post by jfc4120 »
@Roy_043 In the previous version I used the same geometry and made a sketch. However the angles in the previous version was correct in draft mode. The only slight difference is I make the line in the sketch a little longer, otherwise all is the same. I did try again in current version with a longer line, but still get wrong results i draft mode.
The thing is: The angle is correct, but draft mode puts the wrong angle.
