Not fully-constrained, but FreeCAD thinks so
Frotz
Post by Frotz »
I don't think this one is related to https://forum.freecadweb.org/viewtopic.php?t=35743 or https://forum.freecadweb.org/viewtopic.php?f=3&t=35636.
I have a sketch of something that clearly has one degree of freedom, yet FreeCAD reports this as fully-constrained and the sketch passes Sketcher validation. I can even move up and down the horizontal line just below the dark blue vertical line (construction geometry). What's going on here?
OS: Debian GNU/Linux 11 (bullseye) (MATE/mate)
Version: 0.21.0.31702 (Git)
Build type: Unknown
Hash: 633a6e825ca37cc7111fbfa8d7a53ec23e1c29bd
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.1
  * Assembly3 0.11.4
  * Pyramids-and-Polyhedrons
  * sheetmetal 0.2.60
  * freecad.gears 1.0.0
  * A2plus 0.4.60g
  * fasteners 0.4.50
  * Manipulator 1.4.9
bad-fully-constrained.FCStd
(14.58 KiB) Downloaded 29 times
Shalmeneser
Re: Not fully-constrained, but FreeCAD thinks so
Post by Shalmeneser »
CAN YOU HIDE THE GRID NEXT TIME :evil:
(don't understand how you can stand this horror)
The blue 'blue' line cannot be perpendicular because 23=22=20 and vertical constraints on this vertical.
@abdullah : It's a bug/problem in sketcher solver.
You should not create a new point for your symmetry but use symmetry with axis instead.
You need 53 constraints, but me 38, and @chrisb will need ...
fully-constrained_SHALM.FCStd
(15.85 KiB) Downloaded 18 times
Shalmeneser wrote: Sun Jan 29, 2023 12:04 am You need 53 constraints, but me 38, and @chrisb will need ...
Thanks for the compliment :D , but I will not redo this. (And I'm glad that my graphics card doesn't show the grid properly).
It should be noted, that this sketch uses indeed very few dimensions, that's well done!
We had in the past already an issue with equality constraints, and it was discussed here in the forum. And yes, if I remove Constraint23 the effect vanishes immediately. I can then even re-add the equality constraint between these selected lines:
@abdullah, some questions:
- do you need a github ticket?
- do you need the file in the state before it happens?
- should I simplify it as far as possible?
jnxd
Post by jnxd »
chrisb wrote: Sun Jan 29, 2023 1:49 am @abdullah, some questions:
In general it's best to make a new ticket. With the new contributing guidelines that's the targetted way to go.
Simplifying will help if you can replicate the issue with a samaller case.
@Frotz, can you please create a ticket. You can attach this file to it, it is slightly simplified.
It's still the same two lines which show the error when equality is applied.
The effect vanishes if (e.g.) this selected line is removed:
bad-fully-constrained_cb.FCStd
(4.37 KiB) Downloaded 13 times
openBrain
Post by openBrain »
Something important to notice in this example is that there is a redundant constraint somewhere (most probably it's a partially redundant with a symmetric or coincident constraint -- most probably the sooner).
Indeed the sketch has 76 DOFs and the constraints consume ... 76 DoF.
That would be good to know if originally it was undetected by the solver, or detected but ignored by the user. :)
openBrain
Post by openBrain »
OK, finally as said by @chrisb problem seems to be brought by equality.
The redundancy is present in the wire loop formed by the left vertical bar of the 'H' shape.
Starting from the extreme left :
* The most left vertical line is constrained 'vertical'
* Then the top and bottom lines linked to it are constrained 'horizontal' and 'equal'
* Then all the lines closing the loop (3 normal + 2 construction) are all constrained 'vertical', which is redundant
I guess it's not so obvious to detect as the equality constraint could be "flipped" (each horizontal line going in opposite direction), and so if not all vertical lines were constrained 'vertical', there will be another valid solution.
I don't think that the flipping affects the solver, at least not in general. If I remove the right upper horizontal line as indicated above, and I then add the equality, the solver correctly reports the redundancy. The flipping situation is the same as before.
Frotz
Post by Frotz »
domad
Post by domad »
Greetings to the Community!
The gif shows the erroneous behavior of complete geometry constraint, not if this animation can be useful (@abdullah ) for the purpose of locating the problem.
