selfscripted face with hole
lagunax
Post by lagunax »
hi all. have a script that creates a some face. but need to draw with hole in it.
have array in type of
points=
	[list of Vectors of outer border],
	[list of Vectors of inner hole]
macro like
class holedface:
	def __init__(self, obj,points)
	    obj.Proxy = self
        obj.addProperty("App::PropertyVectorList", "PointList", "Additional", "List of points as [array]")
        obj.PointList = points
        obj.setEditorMode("PointList",2)
class ViewProviderControlFace:
    def __init__(self, obj):
    def attach(self, obj):
    def updateData(self, fp, prop):
        "If a property of the handled feature has changed we have the chance to handle this here"
        # fp is the handled feature, prop is the name of the property that has changed
        #App.Console.PrintMessage("Change property: " + str(prop) + "\n")
        if (str(prop) != "NormalDefault"):
            if str(prop) != "Normal":
                rot=fp.Placement.Rotation
                fp.Normal = rot.multVec(fp.NormalDefault)
                if str(prop) != "NormalStart":
                    plac=fp.Placement.Base
                    fp.NormalStart = fp.NormalStartDefault + plac
                    fp.NormalEnd = fp.NormalEnd + plac
        if prop == "Shape":
            s = fp.getPropertyByName("Shape")
            self.data.point.setNum(len(fp.getPropertyByName("PointList")))
            cnt=0
            for i in s.Vertexes:
                self.data.point.set1Value(cnt,i.X,i.Y,i.Z)
                cnt=cnt+1
            for numpoint in range(0,len(fp.getPropertyByName("PointList"))-1):
                self.face.coordIndex.set1Value(numpoint,numpoint)
            self.face.coordIndex.set1Value(numpoint+1,0)
            self.face.coordIndex.set1Value(numpoint+2,-1)
so i can draw solid face with list of vectors of outer border. but how can i make hole?
tried make one list with adding additional edges connecting one point on outer border and on point on inner hole. but it is 2 edges with same vertices and finally this case works wrong (some part of face not show).
Re: selfscripted face with hole
with a proper order of vertexes this coul be achieved with:
"""Test Code.
file: 20230128-polygon_with_holes.py
This code was written as an sample code
for "FreeCAD Forum"
Author: Carlo Dormeletti
Copyright: 2023
Licence: CC BY-NC-ND 4.0 IT
import FreeCAD
import FreeCADGui
from FreeCAD import Placement, Rotation, Vector
import Part
from math import pi, sin, cos
DOC_NAME = "test_polygon"
if FreeCAD.ActiveDocument is None:
    FreeCAD.newDocument(DOC_NAME)
# test if there is an active document with a "proper" name
if FreeCAD.ActiveDocument.Name == DOC_NAME:
    print("DOC_NAME exist")
else:
    print("DOC_NAME is not active")
    # test if there is a document with a "proper" name
    try:
        FreeCAD.getDocument(DOC_NAME)
    except NameError:
        # print(f"No Document: {DOC_NAME}")
        # print(f"Document Created: {DOC_NAME}")
DOC = FreeCAD.getDocument(DOC_NAME)
GUI = FreeCADGui.getDocument(DOC_NAME)
VIEW = GUI.ActiveView
# list of vertexes or even a simple list of "tuples of coordinates"
face_points = [
    (0,0,0),
    (10,0,0),
    (10,10,0),
    (0,10,0),
    (0,0,0)
hole1_points = [
    (5,5,0),
    (7,7,0),
    (4,7,0),
    (5,5,0)
] # same as above
wire = Part.makePolygon(face_points)
face = Part.Face(wire)
hole1 = Part.makePolygon(hole1_points)
face1 = Part.Face(hole1)
hole2 = hole1.copy()
hole2.translate(Vector(0,-3,0))
face2 = Part.Face(hole2)
DOC.recompute()
face_wh = face.cut([face1, face2])
solid = face_wh.extrude(Vector(0, 0, 50))
# uncomment these if you want to see individual components
# face_do = Part.show(face, "face")
# hole1_do = Part.show(face1, "face1_hole")
# face_wh_do = Part.show(face_wh, "face_with_holes")
solid_wh_do = Part.show(solid, "solid_with_holes")
DOC.recompute()
VIEW = FreeCAD.Gui.ActiveDocument.ActiveView
VIEW.viewAxometric()
VIEW.setAxisCross(True)
VIEW.fitAll()
for ease I have used only polygons, but you could create various things, the cut will be done.
Hope it helps.
lagunax
Post by lagunax »
i see this way, but not that i finaly need. i create fully parametrized object where i need to get and understand about structure, but in your case vertex-structure is too hard to understand and to manipulate. as i see now viewer makes some calculations with edges and there vertices, but finaly can't get how it calculates.
for example, i have array of vertices like in next example and it creates strange face. all vertices follows one by another and edges directions everywhere are same (from first vertice to last). in both right coinciding edges face (circled yellow) looks fine, but left one cuts triangle (circled red). and i can't understand how i need to calculate this vertices order to remove unwanted triangle-hole.
import Part
from FreeCAD import Vector
hole=[
    Vector (-79.973953, 50.321354, 0.0),
    Vector (-88.933395, 50.321354, 0.0),
    Vector (-79.973953, 60.71704434135796, 0.0),
    Vector (-79.973953, 67.600258, 0.0),
    Vector (-78.26062431059376, 62.70502914086129, 0.0),
    Vector (-60.988506, 82.745964, 0.0),
    Vector (27.752516, 82.745964, 0.0),
    Vector (76.38942000000002, 50.321354, 0.0),
    Vector (36.28531300000001, 50.32135400000001, 0.0),
    Vector (9.13436615542237, 50.321354, 0.0),
    Vector (-22.305705886726102, 50.321354, 0.0),
    Vector (-34.407871025094536, 50.321354, 0.0),
    Vector (-50.64248908776637, 50.321354, 0.0),
    Vector (-37.94997, 24.936300000000003, 0.0),
    Vector (-14.698114000000004, 33.469097, 0.0),
    Vector (36.285313, 12.563754000000003, 0.0),
    Vector (-79.973953, 12.563754000000003, 0.0),
    Vector (-73.92634158150027, 50.321354, 0.0),
    Vector (-65.04158, 24.936300000000003, 0.0),
    Vector (-60.585687262534236, 50.321354, 0.0),
wire = Part.makePolygon(hole)
solid_wh_do = Part.show(face, "solid_with_holes")
when i create face with my code from topic, then all goes revers: yelloows cuts triangles, but red looks fine
No calculations involved, you pass to makepolygon a list of ordered vertexes, I usually use counterclockwise drawing order.
first vertex and last vertex must be same point to close the polygon.
It is simple enough to be straightforward.
To make a cut shapes must intersect as you cut faces then extrude the resulting face.
Nothing exotic.
Used in this plain way there are no problems.
I don't know if you pass random points if the makepolygon code as a way to guess if there are sequences and try to create polygons, grouping some if them. But I usually don't rely too much on shape recognition algorithms.
Maybe:
help(Part.makePolygon)
could gave some hints.
lagunax
Post by lagunax »
added first vector to end of list 'hole' and nothing changes, still hole in red circle :? also extruded solid have holes in this place
and i need face, not shape :roll:
lagunax wrote: Sun Jan 29, 2023 5:01 pm added first vector to end of list 'hole' and nothing changes, still hole in red circle :? also extruded solid have holes in this place
Post some code to see what you means, code posted is not creating multiple faces as there are only a makePolygon instance.
edwilliams16
Post by edwilliams16 »
edwilliams16
@lagunax
Here's the basic idea:
doc = App.ActiveDocument
shp = doc.getObject("RegularPolygon").Shape
outerwire = Part.Wire(shp.Edges)
shp = doc.getObject("RegularPolygon001").Shape
innerwire = Part.Wire(shp.Edges)
face = Part.Face([outerwire, innerwire], 'Part::FaceMakerCheese')
Part.show(face, "HoledFace")
Screenshot 2023-01-29 at 1.01.15 PM.png (10.6 KiB) Viewed 724 times
Screenshot 2023-01-29 at 1.04.48 PM.png (24.96 KiB) Viewed 722 times
holedface.FCStd
(4.03 KiB) Downloaded 13 times
lagunax
Post by lagunax »
onekk wrote: Sun Jan 29, 2023 9:49 pm
last used this code
import Part
hole=[
#solid_wh_do = Part.show(face, "solid_with_holes")
solid = face.extrude(Vector(0, 0, 50))
Probably it is not clear enough that you have to state what points are the outer wire and what points are holes.
See the code below, with some abstraction to make things more pythonic.
import Part
hole=[
def show_points(list_of_points, solid=False, thick=10):
    for v_idx, v3d in enumerate(list_of_points):
        vtx = Part.Vertex(v3d)
        Part.show(vtx, f'vtx_{v_idx}')
def make_polygon(points):
    if solid is True:
        solid_wh = face.extrude(Vector(0, 0, thick))
        solid_wh_do = Part.show(solid_wh, "solid_with_holes")
show_points(hole)
#outer_points = []
#face =  make_polygon(outer_point)
# for every hole you SHOULD make a polygon
#hole_points = []
#hole1 = make_polygon(hole_points)
# the cut is better to be done on faces and then extrude to a solid, to avoid coplanar issues
#face_with_holes = face.cut([hole1, hole2, ...])
#solid_wh = face_with_holes.extrude(Vector(0, 0, thick))
will return:
Help on built-in function makePolygon:
makePolygon(...) method of builtins.tuple instance
    makePolygon(pntslist) -- Make a polygon from a list of points
    Args:
        pntslist (list(Vector)): list of Vectors representing the
            points of the polygon.
    Returns:
        Wire: Part.Wire object. If the last point in the list is
            not the same as the first point, the Wire will not be
            closed and cannot be used to create a face.
As said in preceding posts.
