Museum Work
mario52
Re: Museum Work
Post by mario52 »
Hi
Bernardo wrote: Wed Feb 01, 2023 11:48 am What i'd like to have? A measure tool to calculate the length of an arc.
have you tried:
Manipulator_Workbench Image general move and info
QuickMeasure
Macro_FCInfo Image length of arc, radius, if it is bspline the approximate radius on point is displayed and many other info
Macro_FCInfo_ToolBar Image mini FCInfo in a toolBar you configure only what you want display
if you want other options then ... juste demander
Bernardo wrote: Wed Feb 01, 2023 11:48 am Ancient Greek architecture - at its peak - was very sophisticated in its modification of geometric primitives. Looking at a Greek temple you might perceive column shafts as cones and are positioned vertically, entabulatures as perpendicular blocks and so on. They are not. You might look at these sketches (not from me) to see the the basic idea.
http://www.enzyklopaedie.ch/dokumente/D ... tempel.jpg
https://external-content.duckduckgo.com ... ipo=images
incredible !!!
mario
thschrader
Re: Museum Work
Post by thschrader »
Bernardo wrote: Wed Feb 01, 2023 11:48 am ...
Go to Arch-wb, activate the "Survey" tool (the blue helmet).
You can measure length, area, volume. Works with Spline curves too...
The lower left corner of the blue marker indicates the center of gravity.
Bernardo
Re: Museum Work
Post by Bernardo »
OK, got it. Thx all.
