[INFO] Installing VirtualBox may break your building toolchain (on 22.04)
openBrain
Post by openBrain »
Just for the record in case it happens to someone else.
On my Kubuntu 22.04 (but I guess other distros may be concerned), I installed VirtualBox (packaged from official distro) and doing this all of a sudden broke my building toolchain.
When trying to compile, I get error messages saying that it cannot find all kind of standard libs like '<string>' or '<iostream>'.
Reconfiguring Cmake failed with error message saying '/usr/bin/ld: cannot find -lstdc++'.
I had some hard time figuring out what was going wrong, but it happened that VirtualBox needed gcc-12 for some dkms support so it installed it as a dependency.
I originally had gcc-11 and g++-11 installed. The problem was that VirtualBox installed only gcc-12 but not g++-12.
Don't ask me why, but such configuration prevents compiler to find the standard C++ library.
So if you see such errors, ensure your highest gcc and g++ versions are same.
After manually installing g++-12, everything was back working.
BTW, I use Clang to compile, not GCC, so it's not linked to actually "using" gcc/g++ to build FreeCAD (however as you can see I use the std lib from GNU).
Help was found here : https://stackoverflow.com/a/74832544/20527947 :)
