How to check if an object has been deleted?
Roy_043
Re: How to check if an object has been deleted?
Post by Roy_043 »
Another example where @chennes's delay code can solve a problem:
https://forum.freecadweb.org/viewtopic. ... 71#p657271
And another workaround... :mrgreen:
chennes
Post by chennes »
Hilarious -- I never imagined that code being in the actual production product, I wrote it for unit testing! I'm glad it's proving useful to someone else :) .
Chris Hennes
Pioneer Library System
Roy_043
Post by Roy_043 »
Instead of using a delay it would be preferable to have a 'kill switch' for the callback of course.
Roy_043
Post by Roy_043 »
Issue for the DiffuseColor bug:
https://github.com/FreeCAD/FreeCAD/issues/8340
Roy_043 wrote: Sat Jan 28, 2023 12:26 pm ...
One issue is:
if obj.TypeId in ("App::"):
This should be:
if "App::" in obj.TypeId:
But even with that mod the code makes certain assumptions that need not apply. "App::" type objects occur as subelements of PD Bodies. but not just there.
For example:
doc.addObject("App::DocumentObjectGroup")
Hello, I've tested today the code, and it is not working for PartDeseign body, or better, if you delete the PartDesign body, the subsequent objects are in the list that probably is a clone and not reflect the document changes.
So the method it trying to delete already deleted objects.
This is a doc.Object printout prior to delete <body_object>.
[<body object>, <App::Origin object>, <GeoFeature object>, <GeoFeature object>, <GeoFeature object>, <GeoFeature object>, <GeoFeature object>, <GeoFeature object>, <Sketcher::SketchObject>, <Sketcher::SketchObject>, <PartDesign::Pad>, <Sketcher::SketchObject>, <PartDesign::Pocket>, <Sketcher::SketchObject>, <PartDesign::Pad>, <PartDesign::Mirrored>, <Sketcher::SketchObject>, <PartDesign::Pocket>]
12:30:23  [<Sketcher::SketchObject>, <Sketcher::SketchObject>, <PartDesign::Pad>, <Sketcher::SketchObject>, <PartDesign::Pocket>, <Sketcher::SketchObject>, <PartDesign::Pad>, <PartDesign::Mirrored>, <Sketcher::SketchObject>, <PartDesign::Pocket>]
This is what is present after having deleted <body_object>.
12:31:56  [<Sketcher::SketchObject>, <PartDesign::Pad>, <Sketcher::SketchObject>, <PartDesign::Pocket>, <Sketcher::SketchObject>, <PartDesign::Pad>, <PartDesign::Mirrored>, <Sketcher::SketchObject>, <PartDesign::Pocket>]
So after some fiddling around I've resolved with this method:
def clear_doc(doc_name):
    """Clear the document deleting all the objects.
    Parameters:
    name       type        description
    doc_name   string      document name
    doc = FreeCAD.getDocument(doc_name)
    try:
        while len(doc.Objects) > 0:
            doc.removeObject(doc.Objects[0].Name)
    except Exception as e:
        print(f'Exception:  {e}')
Roy_043
Post by Roy_043 »
Thanks, doc.RootObjects may also be useful for your task.
To answer the original question:
def isDeleted(obj, doc=None):
    if doc is None:
        doc = App.ActiveDocument
    return obj not in doc.Objects
Roy_043 wrote: Sun Feb 26, 2023 12:47 pm ...
Thanks I have to write down this check.
Roy_043
Post by Roy_043 »
Another solution:
def isDeleted(obj):
    return obj.FullName == "?"
