[Solved] Build fail, python version
looo
Re: [Solved] Build fail, python version
Post by looo »
@chennes Today I saw that the conda build for osx-arm is failing because a wrong python version was found:
-- Found PythonInterp: /Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.9/bin/python3.9 (found suitable version "3.9.6", minimum required is "3")
-- Found PythonLibs: /Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.9/lib/libpython3.9.dylib (found suitable version "3.9.6", minimum required is "3")
CMake Error at /Users/lo/mambaforge/conda-bld/debug_1674297974137/_h_env/lib/cmake/Shiboken2-5.15.8/shiboken_helpers.cmake:468 (message):
  The detected Python minor version is not compatible with the Python minor
  version which was used when Shiboken was built.  Consider building shiboken
  with FORCE_LIMITED_API set to '1', so that only the Python major version
  matters.
  Built with: '3.11' Detected: '3.9'
Call Stack (most recent call first):
  /Users/lo/mambaforge/conda-bld/debug_1674297974137/_h_env/lib/cmake/Shiboken2-5.15.8/Shiboken2Config.cpython-311-darwin.cmake:45 (shiboken_check_if_built_and_target_python_are_compatible)
  /Users/lo/mambaforge/conda-bld/debug_1674297974137/_h_env/lib/cmake/Shiboken2-5.15.8/Shiboken2Config.cmake:5 (include)
  cMake/FreeCAD_Helpers/SetupShibokenAndPyside.cmake:22 (find_package)
  CMakeLists.txt:76 (SetupShibokenAndPyside)
Maybe you can explain what has changed so I can fix the build.
looo
Post by looo »
ok I found a way that works:
using
-D Python3_EXECUTABLE:FILEPATH="$PYTHON" \
instead of
-D Python_EXECUTABLE:FILEPATH="$PYTHON" \
worked.
drmacro
Post by drmacro »
chennes wrote: Fri Jan 27, 2023 1:33 pm
drmacro wrote: Fri Jan 27, 2023 1:06 pm Do you mean when the make directive specified? This is a good question. I would have expected that to override, but I suspect the new merged check doesn't take the directive into account?
The recent tweaks to cMake should move the Python detection to use the standardized find_package architecture. To set the Python location manually, you should set "Python_ROOT_DIR" to the path to your Python installation.
Set Python_ROOT_DIR? as a make directive?
chennes
Post by chennes »
Yes - though per @looo's suggestion above, it might by Python3_, rather than Python_.
Chris Hennes
Pioneer Library System
drmacro
Post by drmacro »
Following instructions found in several places about how to install Python 3.10 on Debian 11 I now have the standard system setup for Python 3.9 (i.e 3.9 is found correctly in /usr/...
The system uses 3.9.
After the instructions for 3.10, I now have a complete directory /home/mac/Python-3.10.8
I modified my usual FC build script as follows:
#!/bin/bash
cd ~/freecad-source
git pull
cd ~/freecad-daily-base-Py3p10
cmake -DCMAKE_BUILD_TYPE=Release -D Python_EXECUTABLE:FILEPATH=/home/mac/Python-3.10.8 -DBUILD_FLAT_MESH=ON -DOCCT_CMAKE_FALLBACK=1 -DFREECAD_USE_OCC_VARIANT="Official Version" ../freecad-source | tee ~/freecad-daily-base-Py3p10-termout.log
make -j5 | tee -a ~/freecad-daily-base-Py3p10-termout.log
cd ~
This does not result in the build using 3.10, it uses the system default 3.9.
The log file indicates:
Summary report
-- BuildType:           Release
-- Compiler:            /usr/bin/c++ (10.2.1)
-- Flags:               -Wall -Wextra -Wno-write-strings
-- Standard:            Requires C++17
-- Python:              3.9.2 [/usr/bin/python3.9] [.cpython-39-x86_64-linux-gnu]
Are there further make directives required? Or is this just not the way to produce an alternate version of FC that uses Python 3.10?
Hmm...thinking about it, are there also Python modules that aren't going to be found in /home/mac/Python-3.10.8?
chennes
Post by chennes »
Try using Python3_EXECUTABLE instead of Python_EXECUTABLE -- we may be explicitly asking for Python 3 in the cmake files, and I don't know how those two variables interact.
Chris Hennes
drmacro
Post by drmacro »
chennes wrote: Mon Jan 30, 2023 7:40 pm Try using Python3_EXECUTABLE instead of Python_EXECUTABLE -- we may be explicitly asking for Python 3 in the cmake files, and I don't know how those two variables interact.
Phooey, I meant to do that and C-n-P'd the wrong things. :oops:
Well that makes it not handle 3.9, but, still doesn't do 3.10...
I went through a couple iterations, currently the cmake line is:
cmake -DCMAKE_BUILD_TYPE=Release -D Python3_EXECUTABLE:FILEPATH=/home/mac/Python-3.10.8/python -D Python3_INCLUDE_DIR=/home/mac/Python-3.10.8/Include -DBUILD_FLAT_MESH=ON -DOCCT_CMAKE_FALLBACK=1 -DFREECAD_USE_OCC_VARIANT="Official Version" ../freecad-source | tee ~/freecad-daily-base-Py3p10-termout.log
And the output is:
CMake Error at /usr/share/cmake-3.18/Modules/FindPython/Support.cmake:606 (file):
  file STRINGS file "/home/mac/Python-3.10.8/Include/pyconfig.h" cannot be
  read.
  /usr/share/cmake-3.18/Modules/FindPython/Support.cmake:2756 (_python_get_version)
  /usr/share/cmake-3.18/Modules/FindPython3.cmake:389 (include)
  cMake/FreeCAD_Helpers/SetupPython.cmake:117 (find_package)
  CMakeLists.txt:46 (SetupPython)
CMake Error at /usr/share/cmake-3.18/Modules/FindPackageHandleStandardArgs.cmake:165 (message):
  Could NOT find Python3 (missing: Python3_LIBRARIES Development
  Development.Embed) (found version "3.10.8")
  /usr/share/cmake-3.18/Modules/FindPackageHandleStandardArgs.cmake:458 (_FPHSA_FAILURE_MESSAGE)
  /usr/share/cmake-3.18/Modules/FindPython/Support.cmake:2984 (find_package_handle_standard_args)
chennes
Post by chennes »
Did you try setting ROOT_DIR instead of EXECUTABLE?
Chris Hennes
chennes
Post by chennes »
drmacro wrote: Mon Jan 30, 2023 8:09 pm
  read.
That looks like a broken cMake installation --
seems like it's expecting a file with the literal name
which is obviously wrong. Maybe try a newer version of cMake?
Chris Hennes
