dialogRunning the Python command 'Draft_ShapeString' failed
JackOfDiamonds
Post by JackOfDiamonds »
I am trying to model for the first time using text.
I am following YouTube videos which explain how to use ShapeString. However, when I click on ShapeString, I get a python error as below. I am not sure if this is an install/configuration problem with my FreeCAD install, or a bug or something else. How should I go about trying to fix this?
OS: Linux Mint 21 (X-Cinnamon/cinnamon)
Version: 0.19.
Python version: 3.10.2
Qt version: 5.15.2
OCC version: 7.5.1
dialogRunning the Python command 'Draft_ShapeString' failed:
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_shapestrings.py", line 75, in Activated
    super(ShapeString, self).Activated(name)
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_base_original.py", line 290, in Activated
    super(Creator, self).Activated(name, noplanesetup)
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_base_original.py", line 154, in Activated
    Gui.Snapper.setTrackers()
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_snapper.py", line 1679, in setTrackers
    self.grid = trackers.gridTracker()
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_trackers.py", line 974, in __init__
    pick.style.setValue(coin.SoPickStyle.UNPICKABLE)
  File "/usr/lib/python3/dist-packages/pivy/coin.py", line 3989, in __getattr__
    field = self.getField(name)
  File "/usr/lib/python3/dist-packages/pivy/coin.py", line 3873, in getField
    return _coin.SoFieldContainer_getField(self, name)
<built-in function SoFieldContainer_getField> returned a result with an exception set
Thanks for the help
kradion
Re: dialogRunning the Python command 'Draft_ShapeString' failed
Post by kradion »
The issue seems to be more widespread. I get the same error when using most commands in the Draft WB (move, rotate, scale, mirror). I report a sample error below. It seems something is wrong with the pivy library.
Version: 0.19.
Qt version: 5.15.2
OCC version: 7.5.1
22:30:34  Running the Python command 'Draft_Scale' failed:
  File "/usr/share/freecad/Mod/Draft/draftguitools/gui_scale.py", line 77, in Activated
    super(Scale, self).Activated(name=self.name)
Roy_043
Post by Roy_043 »
Suggest you both upgrade to V0.20.
Maybe using an AppImage, as from what I know from many forum messages Ubuntu supplied packages are not very reliable.
And There is this warning in:
https://wiki.freecad.org/Installing_on_ ... PA_version
Warning: The FreeCAD PPA is currently unmaintained and looking for volunteers. Please use an alternative (snap, appimage) until the issue is fixed!
mconsidine
Post by mconsidine »
What version of pivy is installed? On my Linuxint install I think v 0.6.5 was the latest in the repository. But a debian version of the latest at 0.6.8 installed and seems to be working fine. I had seen similare errors because I also had versions installed in different paths.
mconsidine
mconsidine wrote: Tue Feb 07, 2023 11:54 am What version of pivy is installed? On my Linuxint install I think v 0.6.5 was the latest in the repository. But a debian version of the latest at 0.6.8 installed and seems to be working fine. I had seen similare errors because I also had versions installed in different paths.
mconsidine
The point is that if you install an AppImage as suggested by FreeCAD page it is working as expected, PPA has problems and is not maintained, if you use a distribution supplied version of FC you have to report error to the distribution packager, and not here.
Plus 0.19 is not maintained anymore and even if is buggy it will not receive updates.
kradion
Post by kradion »
I confirm the AppImage of version 0.20.2 solved the problem. All errors are gone. Thanks for the suggestion.
I naively assumed the Ubuntu package was maintained and up to date. My bad. :)
