[solved] osx: Sketcher: reference dimension: reproducible crash
JimKueneman
Re: osx: Sketcher: reference dimension: reproducible crash
Post by JimKueneman »
TSC wrote: Tue Feb 14, 2023 7:27 pm I have the same issue on a 16“ MacBook Pro with M2 Pro cpu running macOS 13.2 Ventura
I searched the issue tracker at GitHub for this with the keywords "sketcher reference crash", but with no result.
https://github.com/FreeCAD/FreeCAD/issu ... ence+crash
Do we already have a ticket for this or will this be somehow otherwise been taken care of?
I have found this issue in FreeCad 0.20.2 and in FreeCad 0.21.0 on ARM only.
FreeCad 0.20.2 on my Intel MacBook Pro from 2014 does not have this issue.
I have found FreeCad unusable on my new M1 ARM Mac. Sketcher will crash constantly when trying to using constraints. It is not repeatable but too often you click an item after selecting a constraint and FreeCad will just vanish from existence and you have to start open the program again. Use the same constraint again after starting the application again and odds are it will not crash at the same point.
Jim
JimKueneman wrote: Tue Mar 14, 2023 1:05 pm I have found FreeCad unusable on my new M1 ARM Mac.
FreeCAD-Infos?
openBrain
Post by openBrain »
looo wrote: Sat Jan 21, 2023 7:20 pm Using:
May you be able to compile https://github.com/FreeCAD/FreeCAD/pull/9126 and test on a crashing OS version ?
TSC
Post by TSC »
The issue still exists on the current weekly build on my 16“ MacBook Pro with M2 Pro cpu running macOS 13.4 Ventura
FreeCAD_weekly-builds-33357-2023-06-04-conda-macOS-x86_64-py311.dmg
OS: macOS 13.4
Version: 0.21.0.33357 (Git)
Hash: f0560ac2078ad71b4c97b74281990bb916431da9
Python 3.11.3, Qt 5.15.8, Coin 4.0.0, Vtk 9.2.2, OCC 7.7.1
Locale: C/Default (C)
  * fasteners 0.4.55
Sometimes it crashes, sometimes you get a red (driving) dim where a blue (reference) dim should be created.
Message Windows appears with the following:
Unhandled exception in ViewProvider::eventCallback: ('invalid syntax', ('<string>', 1, 59,
"App.getDocument('Unnamed').getObject('Sketch').setDriving(,False)|n", 1, 60))
(Event type: SoMouseButtonEvent, object type: SketcherGui::ViewProviderSketch)
looo
Post by looo »
just updated osx and the error is resolved using this versions:
OS: macOS 14.1.1
Version: 0.22.0dev.34959 (Git)
Branch: main
Hash: 640018bfa7878a79e1b3c220ddd488d66464dc70
Python 3.10.13, Qt 5.15.8, Coin 4.0.0, Vtk 9.2.5, OCC 7.6.3
Locale: German/Austria (de_AT)
  * Plot 2022.4.17
  * AirPlaneDesign 0.4.0
  * CurvedShapes 1.0.4
  * Assembly3 0.12.0
Re: [solved] osx: Sketcher: reference dimension: reproducible crash
Thanks! I will test the next weekly.
looo
Post by looo »
chrisb wrote: Sat Nov 18, 2023 5:27 pm Thanks! I will test the next weekly.
actually I think this was resolved by the osx update, not by changes of the freecad-source.
with this version it works for me with different freecad-versions: OS: macOS 14.1.1
