[solved] osx: Sketcher: reference dimension: reproducible crash
looo
Post by looo »
Using:
OS: macOS 13.1
Version: 0.21.0.31633 (Git)
Hash: e6eb20863974c24256a58e15e341821a94d2418c
Python 3.11.0, Qt 5.15.6, Coin 4.0.0, Vtk 9.2.2, OCC 7.6.3
Locale: German/Austria (de_AT)
  * Plot 2022.4.17
  * AirPlaneDesign 0.4.0
  * CurvedShapes 1.0.4
and
OS: macOS 10.16
Version: 0.21.0.31625 (Git)
Hash: 72df7997700062b6a02f2f208e6291f64073fb88
  * Plot 2022.4.17
no crash with these versions:
  * Assembly4 0.12.5
  * Assembly3 0.11.3
and
  * freecad.gears 1.0.0
  * Plot
I get a crash when using reference constraints.
To reproduce:
1. create a sketch (xy)
2. add a line
3. toggle driving/reference dimensioning
4. add a reference dimension for the created line --> crash
the crash report:
Thread 0 Crashed:: CrBrowserMain Dispatch queue: com.apple.main-thread
0   libc++.1.0.dylib              	       0x1008f59c8 std::__1::moneypunct<char, false>::do_curr_symbol() const + 0
1   libc++.1.dylib                	       0x192e8652c std::__1::basic_ostream<char, std::__1::char_traits<char> >::operator<<(unsigned long) + 404
2   SketcherGui.so                	       0x29f19ed9c void boost::io::detail::put<char, std::__1::char_traits<char>, std::__1::allocator<char>, boost::io::detail::put_holder<char, std::__1::char_traits<char> > const&>(boost::io::detail::put_holder<char, std::__1::char_traits<char> > const&, boost::io::detail::format_item<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >::string_type&, boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >::internal_streambuf_t&, std::__1::locale*) + 596
3   SketcherGui.so                	       0x29f19ea44 void boost::io::detail::distribute<char, std::__1::char_traits<char>, std::__1::allocator<char>, boost::io::detail::put_holder<char, std::__1::char_traits<char> > const&>(boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >&, boost::io::detail::put_holder<char, std::__1::char_traits<char> > const&) + 148
4   SketcherGui.so                	       0x29f19e948 boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >& boost::io::detail::feed_impl<char, std::__1::char_traits<char>, std::__1::allocator<char>, boost::io::detail::put_holder<char, std::__1::char_traits<char> > const&>(boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >&, boost::io::detail::put_holder<char, std::__1::char_traits<char> > const&) + 248
5   SketcherGui.so                	       0x29f1d68ac void Gui::cmdAppObjectArgs<unsigned long, char const (&) [6]>(App::DocumentObject const*, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, unsigned long&&, char const (&) [6]) + 196
6   SketcherGui.so                	       0x29f1d9df4 CmdSketcherConstrainDistance::activated(int) + 3108
7   libFreeCADGui.dylib           	       0x101721184 Gui::Command::_invoke(int, bool) + 520
8   libFreeCADGui.dylib           	       0x101720f40 Gui::Command::invoke(int, Gui::Command::TriggerSource) + 356
9   libQt5Core.5.15.6.dylib       	       0x103931ff8 0x1037ec000 + 1335288
10  libQt5Core.5.15.6.dylib       	       0x10391559c QCoreApplication::notifyInternal2(QObject*, QEvent*) + 176
11  libQt5Core.5.15.6.dylib       	       0x10391559c QCoreApplication::notifyInternal2(QObject*, QEvent*) + 176
Re: osx: Sketcher: reference dimension: reproducible crash
looo wrote: Sat Jan 21, 2023 7:20 pm The crash does not occure with:
Something missing or do you mean the versions mentioned above?
looo
Post by looo »
chrisb wrote: Sat Jan 21, 2023 9:34 pm
SOmething missing or do you mean the versions mentioned above?
you are right, this was wrong. corrected the post.
jnxd
Post by jnxd »
@looo is the stack trace using a debug version? That might give the line where things fail. This might be failing due to some nullptr dereferencing which is only manifested in the macos implementation. I don't have a mac so can't reproduce.
FBXL5
Post by FBXL5 »
I cannot reproduce this chrash on this MacBook. Everything works like expected.
OS: macOS 10.15
Locale: C/Default (C)
  * Reinforcement
  * fcgear 1.0.0
  * Render 2022.4.0
  * fcgear.backup1662890180.767765
  * fasteners 0.4.52
  * sheetmetal 0.2.60
  * Help 1.0.3
  * Curves 0.6.5
  * Assembly3 0.11.4
I cannot reproduce the crash, but I have seen something similar when I wanted to show an angle between external references. I even had sometimes a crash. Those are too added as driven constraints.
In your case I see in report view the same message (as far as I can remember):
Recompute failed! Please check report view.
23:25:28  <class 'SyntaxError'>: ('invalid syntax', ('<string>', 1, 59, "App.getDocument('Unnamed').getObject('Sketch').setDriving(,False)\n", 1, 60))
23:25:28  App.getDocument('Unnamed').getObject('Sketch').setDriving(,False)
OS: macOS 10.16
  * FC_SU
  * DynamicData 2.46.0
  * FeedsAndSpeeds 0.5.0
  * dxf-library
  * fcgear 1.0.0
  * fasteners 0.4.54
  * sheetmetal 0.2.60
  * ExplodedAssembly
  * Curves 0.6.5
When creating an angle for the two external references in Sketch001 I get a slightly different error message:
<class 'SyntaxError'>: ('invalid syntax', ('<string>', 1, 62, "App.getDocument('Unnamed').getObject('Sketch001').setDriving(,False)\n", 1, 63))
23:31:54  App.getDocument('Unnamed').getObject('Sketch001').setDriving(,False)
To reproduce:
- Edit Sketch001 from the attached file
- select both external references
- add an angle constraint
(on second test FreeCAD crashed)
extRef.FCStd
(5.9 KiB) Downloaded 63 times
abdullah
Post by abdullah »
Most likely it is in this line:
https://github.com/FreeCAD/FreeCAD/blob ... .cpp#L2221
The output suggests something might be wrong with the geoid of the geometry.
I do not have a Mac. But setting a debug point in that line should allow to check which string is being provided to the function...
looo
Post by looo »
thanks for the help.
I now compiled freecad in debug mode and get this crash report with lldb:
* thread #1, name = 'CrBrowserMain', queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=2, address=0x1001dd9c8)
  * frame #0: 0x00000001001dd9c8 libc++.1.dylib`std::__1::moneypunct<char, false>::do_curr_symbol() const
    frame #1: 0x0000000192e8652c libc++.1.dylib`std::__1::basic_ostream<char, std::__1::char_traits<char> >::operator<<(unsigned long) + 404
    frame #2: 0x00000002a3fcc720 SketcherGui.so`void boost::io::detail::put<char, std::__1::char_traits<char>, std::__1::allocator<char>, boost::io::detail::put_holder<char, std::__1::char_traits<char> > const&>(boost::io::detail::put_holder<char, std::__1::char_traits<char> > const&, boost::io::detail::format_item<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >::string_type&, boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >::internal_streambuf_t&, std::__1::locale*) [inlined] void boost::io::detail::put_last<char, std::__1::char_traits<char> >(os=<unavailable>, t=0x000000016fdf8ea0) at feed_args.hpp:149:9 [opt]
    frame #3: 0x00000002a3fcc710 SketcherGui.so`void boost::io::detail::put<char, std::__1::char_traits<char>, std::__1::allocator<char>, boost::io::detail::put_holder<char, std::__1::char_traits<char> > const&>(x=0x000000016fdf8ea0, specs=0x0000600003d1f2a0, res="", buf=0x000000016fdf8fa0, loc_p=0x0000000000000000) at feed_args.hpp:197:13 [opt]
    frame #4: 0x00000002a3fcc3d8 SketcherGui.so`void boost::io::detail::distribute<char, std::__1::char_traits<char>, std::__1::allocator<char>, boost::io::detail::put_holder<char, std::__1::char_traits<char> > const&>(self=0x000000016fdf8f40, x=0x000000016fdf8ea0) at feed_args.hpp:291:17 [opt]
    frame #5: 0x00000002a402a38c SketcherGui.so`std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > Gui::FormatString::toStr<unsigned long, char const (&) [6]>(boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >&, unsigned long&&, char const (&) [6]) [inlined] boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >& boost::io::detail::feed_impl<char, std::__1::char_traits<char>, std::__1::allocator<char>, boost::io::detail::put_holder<char, std::__1::char_traits<char> > const&>(self=0x000000016fdf8f40, x=0x000000016fdf8ea0) at feed_args.hpp:301:9 [opt]
    frame #6: 0x00000002a402a370 SketcherGui.so`std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > Gui::FormatString::toStr<unsigned long, char const (&) [6]>(boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >&, unsigned long&&, char const (&) [6]) [inlined] boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >& boost::io::detail::feed<char, std::__1::char_traits<char>, std::__1::allocator<char>, unsigned long const&>(self=0x000000016fdf8f40, x=<unavailable>) at feed_args.hpp:313:16 [opt]
    frame #7: 0x00000002a402a358 SketcherGui.so`std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > Gui::FormatString::toStr<unsigned long, char const (&) [6]>(boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >&, unsigned long&&, char const (&) [6]) [inlined] boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >& boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >::operator%<unsigned long>(this=0x000000016fdf8f40, x=<unavailable>) at format_class.hpp:64:22 [opt]
    frame #8: 0x00000002a402a358 SketcherGui.so`std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > Gui::FormatString::toStr<unsigned long, char const (f=0x000000016fdf8f40, t=<unavailable>, args={j\xd34\xa4\x02\0\0\0}) [6]>(boost::basic_format<char, std::__1::char_traits<char>, std::__1::allocator<char> >&, unsigned long&&, char const (&) [6]) at CommandT.h:69:24 [opt]
    frame #9: 0x00000002a4004a68 SketcherGui.so`void Gui::cmdAppObjectArgs<unsigned long, char const (&) [6]>(obj=0x000000017a29ce00, cmd="setDriving(%i,%s)", args=0x000000016fdf90a0, args={j\xd34\xa4\x02\0\0\0}) [6]) at CommandT.h:383:16 [opt]
    frame #10: 0x00000002a40090ac SketcherGui.so`CmdSketcherConstrainDistance::applyConstraint(this=0x0000600003375180, selSeq=<unavailable>, seqIndex=<unavailable>) at CommandConstraints.cpp:2383:17 [opt]
    frame #11: 0x00000002a40283a0 SketcherGui.so`DrawSketchHandlerGenConstraint::releaseButton(this=0x0000600003520a50, onSketchPos=<unavailable>) at CommandConstraints.cpp:766:30 [opt]
    frame #12: 0x00000002a40afb40 SketcherGui.so`SketcherGui::ViewProviderSketch::mouseButtonPressed(this=0x000000017a785600, Button=1, pressed=<unavailable>, cursorPos=0x0000600000de44f0, viewer=0x000000017a2b2600) at ViewProviderSketch.cpp:894:43 [opt]
    frame #13: 0x000000010198b39c libFreeCADGui.dylib`Gui::ViewProvider::eventCallback(ud=0x000000017a785600, node=0x0000600003b502a0) at ViewProvider.cpp:259:23 [opt]
    frame #14: 0x00000001046d1188 libCoin.80.dylib`SoEventCallback::handleEvent(SoHandleEventAction*) + 200
    frame #15: 0x00000001044e4b30 libCoin.80.dylib`SoAction::traverse(SoNode*) + 124
    frame #16: 0x000000010468d9f0 libCoin.80.dylib`SoChildList::traverse(SoAction*, int, int) + 148
    frame #17: 0x00000001046da2dc libCoin.80.dylib`SoGroup::doAction(SoAction*) + 116
    frame #18: 0x00000001046f4c60 libCoin.80.dylib`SoSeparator::handleEvent(SoHandleEventAction*) + 44
    frame #19: 0x00000001044e4b30 libCoin.80.dylib`SoAction::traverse(SoNode*) + 124
    frame #20: 0x000000010468d9f0 libCoin.80.dylib`SoChildList::traverse(SoAction*, int, int) + 148
    frame #21: 0x00000001046da2dc libCoin.80.dylib`SoGroup::doAction(SoAction*) + 116
    frame #22: 0x00000001046f4c60 libCoin.80.dylib`SoSeparator::handleEvent(SoHandleEventAction*) + 44
    frame #23: 0x00000001044e4b30 libCoin.80.dylib`SoAction::traverse(SoNode*) + 124
    frame #24: 0x00000001044ee2e0 libCoin.80.dylib`SoHandleEventAction::beginTraversal(SoNode*) + 168
    frame #25: 0x00000001044e485c libCoin.80.dylib`SoAction::apply(SoNode*) + 376
    frame #26: 0x00000001046a5678 libCoin.80.dylib`SoEventManager::actuallyProcessEvent(SoEvent const*) + 104
    frame #27: 0x0000000101929050 libFreeCADGui.dylib`SIM::Coin3D::Quarter::QuarterWidget::processSoEvent(this=<unavailable>, event=<unavailable>) at QuarterWidget.cpp:1016:36 [opt]
    frame #28: 0x000000010192fdf8 libFreeCADGui.dylib`SIM::Coin3D::Quarter::SoQTQuarterAdaptor::processSoEvent(this=0x000000017a2b2600, event=0x0000600000de44e0) at SoQTQuarterAdaptor.cpp:717:49 [opt]
    frame #29: 0x000000010195f568 libFreeCADGui.dylib`Gui::View3DInventorViewer::processSoEventBase(this=<unavailable>, ev=<unavailable>) at View3DInventorViewer.cpp:2263:23 [opt]
    frame #30: 0x000000010193b024 libFreeCADGui.dylib`Gui::NavigationStyle::processSoEvent(this=0x0000000296fa55e0, ev=0x0000600000de44e0) at NavigationStyle.cpp:1520:29 [opt]
    frame #31: 0x0000000101941654 libFreeCADGui.dylib`Gui::TouchpadNavigationStyle::processSoEvent(this=0x0000000296fa55e0, ev=0x0000600000de44e0) at TouchpadNavigationStyle.cpp:267:32 [opt]
    frame #32: 0x000000010193ad88 libFreeCADGui.dylib`Gui::NavigationStyle::processEvent(this=0x0000000296fa55e0, ev=0x0000600000de44e0) at NavigationStyle.cpp:1491:23 [opt]
    frame #33: 0x000000010195f528 libFreeCADGui.dylib`Gui::View3DInventorViewer::processSoEvent(this=0x000000017a2b2600, ev=0x0000600000de44e0) at View3DInventorViewer.cpp:0:31 [opt]
    frame #34: 0x0000000101920550 libFreeCADGui.dylib`SIM::Coin3D::Quarter::EventFilter::eventFilter(this=0x0000600000347dc0, obj=<unavailable>, qevent=0x000000016fdfa000) at EventFilter.cpp:167:50 [opt]
    frame #35: 0x0000000103a79854 libQt5Core.5.dylib`QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) + 188
    frame #36: 0x0000000100fd023c libQt5Widgets.5.dylib`QApplicationPrivate::notify_helper(QObject*, QEvent*) + 204
    frame #37: 0x0000000100fd2028 libQt5Widgets.5.dylib`QApplication::notify(QObject*, QEvent*) + 4460
    frame #38: 0x0000000101640cec libFreeCADGui.dylib`Gui::GUIApplication::notify(this=0x000000016fdfc5d8, receiver=0x00006000058e9540, event=0x000000016fdfa470) at GuiApplication.cpp:85:34 [opt]
    frame #39: 0x0000000103a7959c libQt5Core.5.dylib`QCoreApplication::notifyInternal2(QObject*, QEvent*) + 176
    frame #40: 0x0000000100fd098c libQt5Widgets.5.dylib`QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) + 672
    frame #41: 0x0000000101008c84 libQt5Widgets.5.dylib`___lldb_unnamed_symbol13541 + 888
    frame #42: 0x00000001010082e8 libQt5Widgets.5.dylib`___lldb_unnamed_symbol13535 + 248
    frame #43: 0x0000000100fd0258 libQt5Widgets.5.dylib`QApplicationPrivate::notify_helper(QObject*, QEvent*) + 232
    frame #44: 0x0000000100fd10bc libQt5Widgets.5.dylib`QApplication::notify(QObject*, QEvent*) + 512
    frame #45: 0x0000000101640cec libFreeCADGui.dylib`Gui::GUIApplication::notify(this=0x000000016fdfc5d8, receiver=0x0000600002658480, event=0x000000016fdfaaa0) at GuiApplication.cpp:85:34 [opt]
    frame #46: 0x0000000103a7959c libQt5Core.5.dylib`QCoreApplication::notifyInternal2(QObject*, QEvent*) + 176
    frame #47: 0x0000000103169344 libQt5Gui.5.dylib`QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 1236
    frame #48: 0x000000010315a6ec libQt5Gui.5.dylib`QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 108
    frame #49: 0x0000000106d79930 libqcocoa.dylib`___lldb_unnamed_symbol3698 + 44
    frame #50: 0x0000000193004a18 CoreFoundation`__CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 28
    frame #51: 0x00000001930049ac CoreFoundation`__CFRunLoopDoSource0 + 176
    frame #52: 0x000000019300471c CoreFoundation`__CFRunLoopDoSources0 + 244
    frame #53: 0x0000000193003320 CoreFoundation`__CFRunLoopRun + 836
    frame #54: 0x0000000193002888 CoreFoundation`CFRunLoopRunSpecific + 612
    frame #55: 0x000000019c6d7fa0 HIToolbox`RunCurrentEventLoopInMode + 292
    frame #56: 0x000000019c6d7c30 HIToolbox`ReceiveNextEventCommon + 236
    frame #57: 0x000000019c6d7b2c HIToolbox`_BlockUntilNextEventMatchingListInModeWithFilter + 72
    frame #58: 0x0000000196284424 AppKit`_DPSNextEvent + 632
    frame #59: 0x00000001962835b4 AppKit`-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 728
    frame #60: 0x00000001962779e4 AppKit`-[NSApplication run] + 464
    frame #61: 0x0000000106d78bb4 libqcocoa.dylib`___lldb_unnamed_symbol3674 + 968
    frame #62: 0x0000000103a77428 libQt5Core.5.dylib`QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 312
    frame #63: 0x0000000103a79a80 libQt5Core.5.dylib`QCoreApplication::exec() + 120
    frame #64: 0x000000010158e520 libFreeCADGui.dylib`Gui::Application::runApplication() at Application.cpp:2265:9 [opt]
    frame #65: 0x00000001000055a0 freecad`main(argc=<unavailable>, argv=<unavailable>) at MainGui.cpp:270:13 [opt]
    frame #66: 0x0000000192bfbe50 dyld`start + 2544
trying to set a breakpoint I get this:
(lldb) breakpoint set --file CommandConstraints.cpp --line 2221
Breakpoint 1: no locations (pending).
WARNING:  Unable to resolve breakpoint to any actual locations.
So I am not sure this is a proper debug build.
the cmake summary reports that it is a debug build:
Summary report
-- Build type:          Debug
jnxd
Post by jnxd »
looo wrote: Sun Jan 22, 2023 8:53 am
Usually in gdb there's a "pending" breakpoint put up if the program isn't run. Recently my debug builds have stopped breaking at the points, though. A build with "RelWithDebugInfo", however, is working.
